Intake Manifold Replacement - Who has done it?
I do not own a eco but do they not make a EGR delete kit for this platform? if so is there any drawbacks? ive been looking at trading in for a newer ram and going eco route for better mpg
i would not recommend the ecodiesel if you plan on keeping it. lease okay i guess.
your kidding right?
Was this simple for you to do?
No, I wouldn't say this was a simple one. Took me and a mechanic buddy about 8hrs including some snack breaks. Working on this thing sucks.....we are basically laying and sitting in the engine bay. I have a lot more respect for the guys who wrench on these pickups all day long.
For me the worst of it was all the connectors. There are so many plugs. Its easy to get them all sorted and reconnected at the end but many of them were a real pain to disconnect. Hard to reach, impossible to see and each one is a little different. Some of the red latches pull towards the back, some to the side, some don't have any. Needed to take the driver side wheel well liner out to get to one since the latch was stuck. The glow plug connectors suck, ended up breaking one but still seems to be on there.
  • Like
Reactions: c3k
your kidding right?
I'm here for the long haul. We will see how long it goes! Honestly so far its been a great ownership experience. Ordered it new and I'm now 127k miles in. This was my first repair, other issues were covered by recalls.
i have no experience with them but this video scared me off
Big fan of “I Do Cars” channel. Eric does a tear down every Saturday night, would highly recommend his channel to any gear heads. He’s done 2 Ecodiesels so far, both were second gen though I believe. Ugh, modern (emissions systems intact) diesels can hold a lot of carbon in them.
The emissions stuff sucks for sure and its a shame its required. Previous gen had issues for sure with egr coolers and rod bearings. My theory based on how I see dealers operate is a lot of these ecodiesels just weren't maintained well by them. Probably wrong oil types, overfilled, underfilled and so on. Then people push the intervals which doesn't help. Something else I notice is a lot of people just think because its a diesel that it can just do it all, pull 15k lbs and go forever. That's not the case with these little baby diesels.
Where is the Map sensor located ? I'm having trouble finding it on my 2020. I see the EGR tube but not the map sensor is it hidden?
I just did this job. It was intimidating for sure. But it's done now. Code was for swirl valves, used the dorman intake. I did not have to remove the fuel rails or accompanying lines to the Injectors. Do have to remove the fuel line that crosses over rail to rail. The wire harness is a pita, clips too. Took lots of pics and kept things organized. Topside creeper, good lights, T30 torx, long needle nose pliers, pen size extension magnet, right-angle 1/4 drive adapter, 1/4 rachet wrench, 19mm fuel inj socket, 1/4 wobble extension set...think thats all for the more useful tools beyond the regular 8 and 10mm stuff. My intake was surprisingly clean. One side of the intake was not moving with the bevel gear.
congrats! i like a guy that fixes his own chit.....
Nicely done! I'm not sure how you managed to get that out or back in without taking that driver side fuel rail off. I fought with it for a while but before starting the job I made the mini torx tool needed so i just took the rail off.
Also just googled top side creeper.......that would of made this soo much easier. I bet half my efforts were climbing into the engine bay, finding a comfortable spot and 5 min later getting out to stretch. I just spend the week down in Arkansas, the weather was awesome!
This was on a 2020 ram with the 3rd gen motor. Not sure if that made the difference with getting the intake out without removing the fuel rail. Vs the earlier fen. I read everywhere you have to take the rails off..
Has anyone had luck cleaning the OE intake and valves? Or everyone just buying the replacement OE or Doorman?
Currently fighting an active P200a code...
TIA
Instead of me replacing the intake manifold I will rig up a spoon or a little shovel connected to camera snake with a light on it. I will slowly shovel or remove as much soot as possible. It will take days and that's okay. I will see how that goes before I replace one. I will add stiction eliminator in my oil too from hotshots secret.
You get get a camera snake cheap on TEMU
Got the manifold off yesterday and the new one out in. I’ll be wrapping it all up later this evening hopefully. Getting that wiring harness out of the way was a pain. The ALLDATA procedure wasn’t all that helpful apart from getting torque values, and some close up images of connectors.
Looking at the old one, the driver side swirl valves looked much worse than passengers and the actuator was broken. The inlet ports on the engine didn’t look too bad at all. Looks like most of the soot stuck to the intake manifold and swirl valves. It was getting late so I didn’t snap a pic of those unfortunately. Have a few of the old intake for reference. Cleaned the egr tube and looks as good as new once it warms up outside I think I’ll just do the diet and keep racking up the miles. This is definitely a tough job, thankfully a friend who was a mechanic for many years helped me out with his top notch tools and skills. The bolts on the rear of the intake were tough to get out and in. Fuel rail wasn’t bad once we cut a t40 bit in half to shorten it so it would fit.
I tried really hard to get it out without taking the driver side fuel rail off but there was no chance.
View attachment 196850View attachment 196851View attachment 196852
So how did you get the wiring harness off? I am struggling with mine right now. The videos I have found are all for the 4th gen RAM or Jeeps and the harness looks different. Did you take the harness off of one side and swing it to the other? If so, which side did you take it off of? Also, what the heck is holding the harness down in the middle?
Sorry, just seeing this now. I don't get around to checking the forums to often anymore. I'm sure by now you sorted it out. I took the harness off mostly from the drivers side and moved it towards the passenger side as best as possible. I think there were 2-3 bolts that held the hardness down in the center. I know its not the most helpful but honestly i don't remember at this point. I just followed each wire to the plugs, unplugged them and eventually was able to remove the bolts that hold the harness and swing it towards the passenger side. On the bright side, truck is still running well with no issues since, rolled 160k the other day. Still fully stock.
  • Like
Reactions: c3k
I observed a hissing noise during acceleration. Initially, I did not consider it significant; however, I subsequently experienced reduced engine power and increased fuel consumption. I continued to drive the vehicle, but recently the engine warning light activated. The vehicle was inspected, and it was determined that the diesel particulate filter (DPF) was 85 % obstructed. The filter was removed and professionally cleaned; however, the symptoms persisted after reinstallation.
A subsequent inspection of the vacuum hoses revealed a leakage in the intake manifold. Currently, I lack information on how to remove the intake manifold for this specific engine model. Available documentation pertains only to older Dodge Ram vehicles, and I believe there are differences between the 2015 and 2021 engine designs.
RAM Limited 2021 3.0 EcoDiesel
Hopefully this helps. It covers the 3d gen engines.
Thank you for your assistance.
On Saturday, I will perform a complete software-based EGR deactivation via ECU recalibration, including suppression of EGR-related diagnostics, fault codes, and monitoring routines. On Tuesday, I will mechanically remove the entire EGR system, including the EGR valve, EGR cooler, associated piping, sensors, and the intake manifold, followed by installation of a new intake manifold. For this operation, I have purchased a 2020+ Gen3 EcoDiesel EGR removal kit from Great White North Diesel.
