Possible etorque issue?
22psc
So 2 weeks ago finally got back into a truck after being with out one for two years. I bought a 2022 ram Laramie with the etorque. All of the sudden it started having trouble charging the battery randomly. Some days it’ll be perfectly fine and then boom randomly I’ll start getting the low voltage battery alert and it’ll drop down in the 11’s. I replaced the 12 volt battery and it did not fix the issue. It’s currently throwing these codes with a check engine light. The dealership is going to try and see if they can get it goodwilled from ram since it’s at 81k miles.
P0a7d
P0c30
P0daf
It’s strange to me that it’s it’s throwing a state of high and low charge. If anyone has seen this any information would be much appreciated. I’ve literally only had it for two weeks and commute two hours a day round trip for work.
yup sounds like your unlucky day. welcome to the club unfortunately. you can follow along with the most current threat here if you like. good luck.
Mannn if only I knew before I bought it. When I first looked them up I couldn’t really find anything bad now all I’m finding is a massive back order.
I hear that. I wanted the GT package on mine, and the only option at the time was Etorque only. lucky us.
P0a7d
P0c30
P0daf
Yes, sir I have 2022 Ram Laramie with the eTorque and had the same codes at 10,000 miles 6-2025 so they did reprogram so have to go back into the dealer 01-22-2026 for a P0A7D code @ 11,122 miles on the clock. Love this truck, but just the eTorque don't like.
I see they are putting this same set up in the new Ram 5.7 Hemi eTorque 2026 have to see if they fixed anything.
