ramButz
i did mine last year
correctSupposedly the reclining seats have a built in release you can access through the arm rest hole.
This release, is there any way to mod up something to release it from top of seat by the headrest. Did something similar to my F150's/F250.. builtrite makes a piece to do it or you can use some paracord and a keyring... I have to look at my seats to seecorrect
You would have to fabricate spring loaded locking tabs to make that work in the ram. Everything is solid and the motion of the bottom seat lifting pushes on the top part of the seat until the tabs can unlock. There is no “latch” just hard mount points and sliders. The other suggestion would be try to source the laramie seat parts ?
Has anyone figured a way to mount a rifle/long gun rack behind the rear seat against the firewall?
How much room is back there? Might have to be lever action.
It will not. I was nervous because I thought the car seat straps for my son's car seat attached to the seat back. They actually attach to the firewall.I've been tempted to do this, but keep my back seats up often. Always afraid this would cause both back and seat to flop down.
Ive never tried this on a quad cab, I've always had the crew cab trucks. The quad cab does have shorter seats so there are differences. Can you post pics of the seat backs and the hooks on a quad cab? Ill try and help to point you in the right direction.Is it possible that some may be different ? I have a 20 quad cab just trying to do drivers side to access the amp and loc I have back there , I cut the 1 1/2 inch still don’t fold cutoff another 1/2 “ still don’t fold ?? Am I missing something do some not fold ?
