VA3SAM
- Feb 8, 2025
Ran BlueDriver OBD2 code reader and trying to locate the bypass valve. I disconnected negative post for 15 secs and reconnect and ran engine but fault did not extinguish. The following day, I disconnected negative post for a longer duration check engine light went off for 48 hours. The check engine light came back on and won’t go off now
I tried to clear fault code with blue driver app with negative results.
I am include a photo and want to know if this is the bypass valve.
Any suggestions?
Sam
Any suggestions?
Sam
