2025 Limited/Tungsten UConnect Firmware versions
Kilroy
Bethalto, IL
After reading through many posts on various features/options available in the Limited and Tungsten trims with the full digital dash and tech I am discovering that I have at least one feature that is not available in my settings. Primarily the enable side view when the turn signal is engaged. The option for that is not in my camera settings. So I am wondering what software version are there out in the wild, and if perhaps I am going to have to go to the dealer for a tech checkup and make sure my software is all up to date. I do understand that updates are over the air, as long as you have either the wifi subscription or your truck is connected to your home wifi and in range. Mine has been connected to my Wifi at home for a couple weeks now and so far I have seen no changes. So some input on what your trucks are at software/firmware updates would be helpful.
Do you have tow mirrors?
Then you can’t have turn signal activated cameras, because the camera view on the regular side mirrors is straight to the ground.
The tow mirror cameras are aimed more rearward, so their image is straight behind, hence the reason they can also have the trailer reverse guidance views.
So in short, no tow mirrors not turn single camera activation ? Thanks that’s informative!
Correct
Were you ever able to locate a link or web site that lists the UCONNECT 5 Software Update versions and what they are meant to address? I, too, would like to keep up with any OS, Security, or Feature/Function updates as they are released for my 2025 RAM Tungsten. It would be so helpful in troubleshooting those regular, but intermittent issues that keep popping up periodically. I find that the RAM app rarely, if ever captures an issue when it occurs and by the time you make it over to the dealership it may have reconciled on its own. Like I said, issues are regular, but intermittent. I see the updates flash across my screen once they have been installed, but there isn’t any explanation of what they are supposed to be addressing.
