2019 RAM 1500 HEMI TRANSMISSION FLUID CHANGE
1RAMBO15
Hi Ram truck owners!!
I can’t afford the MOPAR transmission fluid and oil pan, can anybody recommend a reliable aftermarket oil transmission fluid kit
Doorman makes an aftermarket pan that has a removable filter so that next go around you wont have to change the entire pan. As for fluid, I wouldn't mess with having to replace a transmisison that expensive.
I would stick with the mopar 8-9 speed fluid. Tranny replacement is not cheap if it lets go. Guy at work had one replaced not too long ago, 5 to 6k IIRC.
Used their kit on my 14 no issues their fluid is suppose to be compatible with the existing ZF Mopar fluid.
Or spend more and go with a PPE pan and be glad filter will now only cost $30 and go with either Mopar 8/9 speed fluid or ZF lifeguard (same as the Moper fluid)
I would not chance it going any cheaper than what I linked.
AMSOIL for engine and trans has never let me down. I don't know about tans filters for the Ram. But I use Wix oil filters for my cars and trucks with no problems.
Better off sticking with the ZF lifeguard or Mopar 8/9 Spd fluid (amazon or ebay) You won’t get all the existing fluid out with a pan/filter swap and last thing you wanna do is mix a fluid that isn’t compatible w/ the factory fluid. ZF/Mopar fluid has that green tint to it.
Edit: better make sure that pan/filter is correct for our platform.
Yeah I know the debate on the fluids. I won't rehash that now. As far as the pan, I believe it should be the same. I've replaced the pan/filter on a BMW with a ZF 8HP transmission before and will make sure to match the old and new before proceeding.
The pans for the Rams are deeper, the BMW pans are flat on the bottom.
Sent from my SM-S928U1 using Tapatalk
I have heard some pans are deeper. The BMW part I purchased measures exactly the same as the pan on my Ram 1500 RWD.
If you can afford the truck you can afford the maintenance.
Hmmm, so what is the issue with trying to purchase parts at a good price in order to save a few dollars?
Not a thing. But that was not the statement. The statement was, 'I can't afford". How ever much it costs is how much it costs.
So I completed the fluid change this weekend. The procedure at Blauparts.com is pretty spot on. One item to note. When removing the 10mm pan drain plug, there is very little clearance between the drain plug and the exhaust crossover. To the point where a hex bit socket likely won't fit, or you won't be able to get a ratchet on the socket. The video shows using a wrench on a screwdriver hex bit. Most screwdriver hex bit sets don't include a 10mm bit. I had some shallow hex socket bits, but had to use an allen key in the socket lock pin hole as a lever to turn the socket. I probably could have used a pair of vise grips on the socket as well since the torque spec is something like 5-6 ft-lbs. If you jack up the back of the transmission prior to draining that might give some added clearance to use a ratchet on a hex socket bit.
When refilling, make sure the vehicle is running for your final level check. If not, you will likely underfill. I removed the fill plug while the truck was at the correct temp and had fluid flowing out. A moment later, I did start the truck and was able to add another quart or so. I ended up adding approximately 5.5-6 quarts in my drain and fill.
What I did when it came to the drain plug was grabbed an old 3/8 10mm hex socket and cut (grinder) the socket portion off. Leaving just the hex.. then using a wrench to loosen it.
I thought about doing this and might have if the allen key in the socket hole didn't work
Just to confirm, you used the BMW part # 68386779AA as you mentioned above? Does it come with the appropriate gaskets/orings?
Liqui Moly ATF 1800 is OK and works fine in the ZF 8HP75 transmission. I used that fluid and it shifts great and used a dorman pan as you buy into their system that you can change the filter layer and not the whole pan. From doing service on two 8HP75 transmissions so far, changing the fluid earlier than 60k miles but if you tow a lot 30k is fine.
This tool is amazing:
I used the part from the link BMW Auto Trans Oil Pan (With Filter) 24118612901 - ZF 1087298247. The link shows the BMW part to be 24118612901, but I can't say I checked the part number before installing. I did physically compare the original ZF cover/filter with the part I purchased, and they looked identical. Both are ZF parts, look the same, have the same magnet plates, have the same preinstalled gasket/o ring.
Hey, I don’t suppose you snapped a picture of those two pans side-by-side did you? Thanks!
