Remote start battery voltage
dad2steph
Virginia
Need some help from E-Torque owners. When you remote start your truck, what is your battery voltage at? When I remote start mine it is at 12.0 volts. Once I actually start the truck it clinbs to 14.3. Seems that the truck is running off the battery when it is remote started. Reason I ask is I wonder what kind of strain this puts on the battery over time. I have already had to have a battery replaced at 2500 miles and wonder if this has something to do with it. Of course the dealership told me this is normal. Thanks for your help.
It’s a 12v system. How much voltage do you think a 12v battery will apply when cranking. The system charges at 14v once the vehicle is running. Actually it’ll probably be less than 12v when cranking due to the cranking load off the starter.
I haven't paid attention but this is definitely concerning. If it is really the case then these 12v batteries will be lucky to last a year. Especially in cold climates.
I am saying that when the truck is running after remote start it is displaying 12V. Then after I push the start button on the dash it goes up to 14. It would seem that the truck should be charging any time the truck is running regardless of how it is started.
Just checked with a a multi meter. When remote started even though my dash says 12.0v the battery was at 14.2v. its just a display issue.
