Eaglehemi345
- May 1, 2021
Recently did fox 2.5 inch suspension lift on 2020 ram 1500. Paired with trx wheels and 325/65/r18 falken wildpeak at4w's.
Belltech rear sway bar (BEL-5563)
1994-2002 ram rear sway bar links(zon-D5508)
Bilstein B12 1" lift springs (53297839)
Icon delta joint tubular upper control arms (218550DJ)
Go rhino D64306T dominator extreme D6 side steps
Ksp 1.5 inch wheel spacers
Tires are 2 inch outside the fenders.
Ride is smooth and comfortable . Minimal body roll. Coilovers are set at 3 inches of front lift. Still have some rake. Overall nice setup. Tires do rub at full lock. Had to install 1.5 inch ksp wheel spacers to clear upper control arms. Anything from 1/2 inch to 1-1/2 spacer will be needed to clear trx spec tires and wheels. Depending on preferred stance.
