Fox 2.5 suspension system
Eaglehemi345
Recently did fox 2.5 inch suspension lift on 2020 ram 1500. Paired with trx wheels and 325/65/r18 falken wildpeak at4w's.
Belltech rear sway bar (BEL-5563)
1994-2002 ram rear sway bar links(zon-D5508)
Bilstein B12 1" lift springs (53297839)
Icon delta joint tubular upper control arms (218550DJ)
Go rhino D64306T dominator extreme D6 side steps
Ksp 1.5 inch wheel spacers
Tires are 2 inch outside the fenders.
Ride is smooth and comfortable . Minimal body roll. Coilovers are set at 3 inches of front lift. Still have some rake. Overall nice setup. Tires do rub at full lock. Had to install 1.5 inch ksp wheel spacers to clear upper control arms. Anything from 1/2 inch to 1-1/2 spacer will be needed to clear trx spec tires and wheels. Depending on preferred stance.
Very pretty. DO NOT add flares. It is seriously clean without them. Great job.
be sure to read here about how to get the best setting for the adjusters.
if you will be adjusting the knobs for on-road and off-road use, get yourself one of these:
that little tool is a god-send and worth every penny!
@Eaglehemi345 (and @boogielander)
Wow - just wow. Great looking truck(s). I drive a 2019 that's pretty similar and put 35x12.5's on the stock 22's and suspension. Works fine, bit of rub at full lock, but virtually no sidewall so I'm overly cautious when aired down. I've been looking for the perfect "next" setup and I think I may have just found it in your mods. Thank you!IMG_7998.jpeg
Wow - just wow. Great looking truck(s). I drive a 2019 that's pretty similar and put 35x12.5's on the stock 22's and suspension. Works fine, bit of rub at full lock, but virtually no sidewall so I'm overly cautious when aired down. I've been looking for the perfect "next" setup and I think I may have just found it in your mods. Thank you!View attachment 195609
thanks hahaha
just copy my homework. i got the head scratching part out for ya already!
all you need to do is come up with the funds for parts and install. if you're in SoCAl hit me up i can hook you up with both parts and install.
  • Like
Reactions: Fab
Well, these actually might give a lil more TRX look....🤔😉
($599.95 painted to match)
