2025 Level 2 Lighting Question
Can’t wait for there to be a way to install oem led taillights that come with the limited. But for now, I plan on replacing the bulbs. Lasfit is kind of pricey, has any tried alternatives that fit without errors? It’s kind of silly that this is a conversation in 2025 for a 75k truck.
I replaced my taillights with LEDs the other day. I think turned out great. No errors or codes. Little weird with the triple unlock blink but otherwise operate very well. A lot brighter than the stock incandescents. Link: Amazon.com
This doesn’t look bad honestly! How are they holding up after two months?
Cost cutting option I am sure, even my Tungsten trim has incandescent bulbs in the visor mirrors. My 21 Limited did as well, I changed them out with LED's but found they were really too bright to use the mirrors.
I swapped in the Lastfit L2s for the tails and reverse lights, and they are awesome. Very bright, reverse lights look like spot lights out the back. I didn’t do the 3rd brake lights as my Recon 3rd brake led light from my 2022 worked flawlessly.
l2 post part numbers. Its crazy we don't have rear leds .
Yea, whoever made that decision at Stalantis should be fired.
I submitted a complaint to Stellantis and now waiting for the Ram survey to mention it. Everyone should too because this is ridiculous. 75k truck with incandescents.
Can someone with the Lasfit brake lights installed help me figure something out here? I noticed after installing the LEDs that they are not synchronized with the other turn signals on the truck. As you can see in the first photo, the amber front and back blinkers are on, and then in the second photo, you can see the back blinkers switch off before the front ones do. A little OCD, but I think it is very noticeable. Just wanted to see if anyone else is experiencing this.
Never looked, I'll have to check this out.
lol no oct just a trackman
Hold off a little bit Jimmy and I are still working on something. I’m going to check the last few wires tomorrow morning.
Reviving this chat because there’s now a solution for this. The guys at Retro shop makes the harness to convert to the 2025 LEDs or the old LED 2019-2024 style. The harnesses I think are running around $250. You will have to email them because it’s not on their website yet. People on the Facebook page are showing great success with them.
what's the website . I want my leds....
Yea, I'm not sure on that. I know they are more expensive because they have the blindspot monitors in them.
i wonder if 24 led will go in i like them better only with black middle
They make a harness for the 19-24 style led light too, they are the same size. You can buy them without the blind spot monitoring. It won’t give you the amber turn signal tho which is bummer, idk why Ram went back to using integrated lights.
Crazy i know for the rebels they had rear leds in the first trucks they showed. Light animation too says on my window sticker. They fixed it now the ones built after september don't show this on window sticker.
You should try and get some money back from Ram for the false advertisement. I’ve seen people do it and were successful.
