Corroding exhaust hanger brackets
gpbst3
Anyone else having issues with the exhaust hanger bracket corroding and breaking? The driver side went last last year and I just ordered a new right side yesterday.
2019 with 48k miles. Southwest PA. Nothing else under the truck shows any excessive rust/corrosion. IMG_7307.jpeg
Mine are cast aluminum. Were these steel at some point?
Or are you actually talking about the actual mount on the truck?
Im not sure what they are made of. Its the highlighted part in my pic. Both side have corroded inside the rubber bushing. I say corroded because there is no rust. I will get a picture later.
They are cast aluminum, mine have surface oxidation on them but nothing serious as of yet.
2019 with 48k miles. Southwest PA. Nothing else under the truck shows any excessive rust/corrosion. View attachment 182672
I saw the title of this thread and my first question was...I wonder if he lives in PA?
Idk what crap we put on the roads here in winter, but it ate up my concrete slab after I parked my car on the slab after driving it during winter.
Have replaced a few for customers. Some just rot away quicker than others.
I’m guessing the aluminum reacts with the metal causing corrosion.
I had that exact thing happen to mine as well. Driver's side at 75k miles, passenger side looks OK for now. I'm in west MI. Was a little surprised there wasn't much info on here about it, so maybe it's not all that common. We just got lucky...
My driver's side rear hanger just broke today. 2019 Ram 1500 Rebel. 66,207 miles. Factory undercoated.
Has anyone personally replaced the driver's side bracket? Mine just went and I'm not going to spend the money on parts if I can't get the bolts out. I got underneath and did notice that an electrical bracket is blocking the top bolt. I can definitely do the work I need need to know if anyone actually was able to do this. The old one literally turned to powder. TIA
Did you get this figured out? I’m currently trying to replace mine.
There is a wiring harness in the way of the drivers side which makes that side more difficult. If I recall you need to unbolt the bracket holding the wiring harness to give your self room to remove the exhaust hanger.
If I was able to do it, you can.
Popping the wire clips out of the bracket helps get to the top bolt. The wiring bracket doesn’t need to be removed. Taking out the wheel well liner helped to see better.
My driver's side rear-most hanger turned to powder too - just like the one pictured above. I have a 2021 Laramie with just 42k mi. I'm almost exclusively on MA & NH roads and the DOT in those states use salt - and other oxidants. But the use of untreated aluminum by RAM is unforgivable. There's another post here about this same problem - but that thread has died.. I'm glad I found this one. The wiring bracket looked to be a problem when I climbed underneath to check out what I would need to complete the replacement. I couldn't really see how it was attached - I just knew it was going to interfere with accessing the top hanger bolt. I was going to return the part but given what I've read here - I've decided to give it a shot. I will likely paint (or coat with a sealant) the entire new bracket to keep it from rotting away again. Lastly: Besides removing the rear wheel well liner - are there any tips to make this job easier? TIA!
