RamTruckMan
Bet it started at the battery, then ignited the fuel tank.
2019 Ram 1500 Bighorn | 5.7L eTorque | 3.92 R.A.R.
You guys that have had the TSBs done and have downshift issues....ask if they "reset the adaptives" for the transmission after doing the TSBs. My durango learned a bad 5-4th downshift. Resetting the adaptives fixed it. I wonder if the poor downshift performance was something the trans learned with the previous programming logic, and should have been completely reset so it functions better with the new programming? Complete guess
Is there any way to clear these yourself? I know a few other makes clear when you disconnect the battery. I suspect they did not clear mine when flashing and would love to try it.
Soo far as I know, it's an OBD thing. After it's done, you'll want to, at a slow to moderate speed drive up through the gears and back down to get a better baseline.
Or is this the sort of thing that will adaptively fix itself over time? Or is it like a bad puppy in that once it learns a bad behavior, it's set for life?
Truck details? Add them to your signature pleaseI just got back from picking my daughter up in Harrison Virginia at college and drove home to Lancaster Pa. I used the adaptive cruise and set it at 80 mph. I was hammering down 81 at a rate of 68 to 80 the entire way, round trip measuring 480 miles. I was pleasantly surprised that I got 18.3mpg at those speeds.
My 19 with non etorque and 5.7 w/3.92 orp, keeps getting worse. I'm at 1500 miles and saw 16.8 mpg on my first 360 mile trip with just the truck. Just got done with a 250 mile trip with a mix of 60 mph and 75 mph running, averaged 15.9 via the truck but will calculate by hand when I fill up on my way home Tuesday but am anticipating less than what the truck told me. Getting 10 - 11 mpg with shorter trips to work ( 7 - 15 miles) love the truck other than the mpg so far, that's the only thing I am missing about my GMC is the additional 3 - 5 mpg. Hoping warmer weather in the spring will greatly improve this. It was 7 - 10 F on my trip down. Maybe should have considered a 3/4 gas I guess but I'm going to be hopeful as I really like the truck otherwise. I will be installing airbags for towing next week and thinking of a hellwig swaybar. I do like seeing the higher mpgs of other members though!
Just got a 2019 ram and experiencing the exact same issues , I dont have etorque . Mds never engages. Somethig is definitly wrong with many of these trucksBought my 19' Ram Rebel with eTorque Hemi on 9/28/18. I had numerous longer trips to take and mileage has built up fast.
Just getting ready to pass over 3,000 miles thanks to a trip from Orlando FL to Central KY and back again.
My issue: horrific gas mileage! I simply can't figure it out. My drive was 1600 miles roundtrip, not towing, with just myself and baggage in the truck.
My fuel mileage (all highway, with cruise control engaged at speed limit) on the way up = 15.0 mpg hwy, my mileage driving back tonight is 14.8 mpg. While the sticker rates the truck at 17 city/22 highway, I never expect to achieve those numbers. But 15 city/ 19 hwy is what I got on my 2011 Hemi. I at least expected that.
This is my 4th Ram, and I know something must be wrong. I'm not dragging a brake as I check brake temps, and they were cool to the touch.
MDS almost never activates and the truck downshifts on even the slightest uphill grade. At 70 mph and 1850 RPM (.392 gears), there's ample torque to never require a downshift on moderate Florida hwy grades.
I'm fearful that the eTorque motor is causing a high amount of drag during hwy driving conditions. I guess it's back to the dealer with my fingers crossed.
This argument drives me crazy. (I'm not trying to target just you, I'm speaking in general here)5600 lbs-3.92 gears-aero of a barn door-33 inch tires-go get a prius-comon man!
