How to replace body mounts... Procedure video?
whiteknight312
Anybody do the front body mounts. Easy or no so? Pop on and off? Is there any videos of this. I can't find any on 5th gen. Thanks
It's very easy to do. You need to loosen the front 6 mounts, the 4 front cab mounts and the two up front. After you loosen them to give the cab room to move, remove the two cab bolts on one side and use a jack to lift the body off the frame on that side only somewhere around the b pillar area. You only need to lift about an inch or 1.5". Once lifted, you can slide the top piece of the mount out and insert the new one. Replace all 4 this way.
One thing I did to eliminate any squeak due to binding was to move the truck a bit after replacing the mounts, but before tightening them. I had the bolts in almost all the way, just not tight, exited my driveway which allowed the frame/body to twist some, then pulled back in and torqued the bolts. DONE.
I have this one saved for when I get around to ordering new mounts, he explains it a bit.
The parts in the link I posted are sitting in a box in my house. Waiting for the weather to get above freezing before I go bust any knuckles under the truck.
It seems like replacing the lower mounts is an easy job. Correct me if I’m wrong but you should be able to just take out the bolt..The lower mount should come out with it. Put the new one in and bolt it up. Tighten it to 90 ft/lbs of torque and then you should be good to go? Is there locktite on it from the factory?
It's not just the lower portion of the mount that needs replacing. The top portion is redesigned with rubber isolation surrounding the bolt hole. The current mount has isolation only in 2 places, causing the metal sides to impact each other during articulation, causing the clunk.
The best way to do it is to loosen all frame bolts (8 of them), then remove the A pillar and B pillar bolt on one side only. Then using a jack, lift up the body of the truck off the frame high enough to slide out the top half of the mount. Put that side back together, do the same on the other side, then torque all 8 bolts.
It's really simple and takes less than 10 minutes per side if you have all the tools already set up. Start to finish should be less than 40 minutes. It's that simple.
The fella in the video said they changed them all after 2021 or so. I have a 23 so i assume i already have the current upper mounts 🤷‍♂️ im not positive My issues is related to the body mounts, but I’m becoming more suspect. My truck was in an accident and while it was being repaired, the frame cracked…so the shop had to replace the entire frame. So there is always a chance one of the mounts has since come a little loose.
Years back, I did a body lift on a jeep by adding spacers underneath of all of the mounts. So I’m pretty familiar with the process, just not necessarily something I want to do unless I have to.
How does this work with the mopar power running boards? Do those have to come off to do the body mounts?
If they’re mounted like any other running board they shouldn’t be in the way…but i dont have them so I’m not sure where or what they cover when they fold up. I think if nothing else you would just need to locate where the power wire runs and make sure it has enough slack to allow you to lift up the body during the replacement process.
I’m thinking more about if I can jack up the body. I’ll have to look at where they cover.
Replaced my swaybar bushings today and during the test drive I felt just the slightest clunk. I’m really hoping it was just things sort of reseating, but if the clunk remains I’m going to go with the body mount route.
I did also tighten my A and B pillar mount bolts and found that all four had a half to nearly a full turn before they were at the 90ft/lbs mark.
I also saw that I have the “old” lower body mounts that have an air gap visible. Just like the ones the guy pointed out in the video linked earlier in this thread… Going to investigate more once the newer lower body mounts I ordered arrive and see if there is a difference. If there is, I’m betting the body mounts are my problem. 🤦‍♂️
Looking under the truck, where would anyone suggest being the lift point to lift the body up after you loosen all of the mounting bolts? The pinch weld on the side maybe?
Sorta found an answer to where to lift the body from..but im going to need a second lift or maybe I can just rest the body on jack stands….either way i think its best to either lift from the B pillar area or from the front and rear at the same time so I don’t torque the body around. IMG_4991.png
I think your problem is the same as mine. I've been meaning to just disconnect my sway bar to see if my clunk goes away, and I also have the body mounts just because.
Finally got around to checking out my sway bar. Took it out completely. The bushings looked ok, but there was some wear. The end links were completely shot. I can move both joints around easily with my hands for both links. Clunk is gone, and I'll probably just leave the sway bar off as the only downside (to me) is a little more body roll. Ran my last truck without one for about 6 years, so I'm used to it. I still have the body mounts, so I'll probably install those just because whenever I have time.
What year and model Ram did you do this to? I have a 2020 1500 so you'd think the cab mounts in the TRX video would work? They look exactly the same except for the rubber surrounding the bolt sleeve. I could be wrong but I'm going to order and see how the compare to the recommended tsb parts.
I used both lower and upper trx mounts in my 2019 Big Horn. They fit perfect.
