Bed cover with Rambox
LennyA80
I’m new to this site and I just bought a 2025 Limited which comes with the Rambox and the Bed utility group which has the cargo tie down hooks and track for them.
I’m shopping for a bed cover that would work perfectly with this set up and one thats fairly easy to install without having to modify or remove the tie down tracks…
Any experience based advise would be much appreciated! Thanks guys
The Mopar Tri-Fold works great with the tie down tracks and ramboxes on my '19. It'll flip up and even completely remove in seconds.
It's pretty water tight, but not as good as the TruXedo TruXport I had on my last truck.
I just got the Lomax tri fold via NAPA for my 25 Limited. It came in under 1300 and included free shipping that came in super quick. I am going to install it this afternoon and see how it goes. It seems per straight forward and works well with the standard silver bed rails.
@Realtruck has some good ones. Generally less money means less water tight, but the quality in general (if you aren't going expensive, aka, hard aluminum) on soft covers, is essentially equal.
If you want to go expensive, most hard deck fold back aluminum covers are pretty good.
There are so many great options out there. I'm happy to help you find one that works best for your set up. Send me a PM or email me at [email protected]!
Diamondback if you want secure and water tight. Made custom for each order in the USA. I have had mine for over a year and am very happy.
So installed the Lomax tri fold on my 25 Limited with the RamBox and I'm impressed. The things I like about it is the pretty easy and straightforward installation. You can do it by yourself for sure. The sealing with the gaskets is very water tight (it actually rained pretty good right after I installed it and there was only minimal drops.
The only thing that I didn't like is the instructions need some serious revamping. Also it might be helpful to have a dedicated video for the RamBox install that's more in depth than what's out there.
Overall I'd say it's a great option for the RamBox. Keep in mind that the way all RamBox tonneau covers go on they will slightly hinder the opening of the RamBox covers, but not very much if you take the time to install things correctly.
Actually, yes they do sell covers that allow full use of the boxes with the cover on and fully closed. My RealTruck cover allows for the boxes to open completely.
I think that the rigid covers may have the interference issues most commonly. I am going to try and place a washer between the bed side and silver rails using the bolts that screw it in. It seems like I'm interfering by maybe 1/4 inch or less but if I can get my covers to open like yours that would be perfect.
Retrax hard cover doesn't interfere with RamBox. You have to have the silver rails though.
Been looking at this one:
Did you end up
did you end up getting it? Wondering how it worked out
I have the silver rails that looks like a good set up…which Retrax did you get theres a handful to choose from on Realtruck
I looked into getting a rolling cover, however decided the tri-fold worked better for my use case. Thanks to this thread and a bit of tinkering, I was able to resolve the interference issue with a couple of washers. It opens a ton better than before... Although now I'm realizing just how massive the RamBoxes really are so I'm not using the bed as much as I used to..
I got the Retrax PRO MX. It's the manually operated w/out T rails. Also ALUMINUM NOT POLYCARBONATE
