AlfaOBD what's needed?
That0ne5thgen
I made another post in a different section in regards to upgrading from halogen to LED headlamps on a 2021 ram 1500. There is a lot of talk that I need to use the alpha old software to change settings to the computer. So besides the alpha old software what else will I need? Will I need a SGW bypass? If so what is a good one? Will I also need an OBD interface module such as OBDLINK MX+? I tried searching the forums for the answers to my questions but unfortunately I didn't have much luck.
Thanks in advance for info and advice!
Yes, you need the interface (OBDLINK MX+, or something similar), and a SGW bypass (if you run a Tazer, that will also act as the bypass). Other than that, you just need a device to run AlfaOBD (laptop, or an Android device I believe).
Thanks for the quick reply. What would be a good cost effective SGW Bypass?
Have you tried search? There's tons of post on here about it already. Also, it's AlfaOBD and not alpha. That might help in your search.
