gskowronek
- Mar 22, 2024
Which one would you choose? Price is very similar.
What are these? model, size?The .5” narrower will likely look odd on the stock rim. Depending on gearing, the bigger tire will have some effect on mpg.
I chose to stay with the stock 285 although I went taller as I have 3.92 gears.![]()
BTW, nice truckThe .5” narrower will likely look odd on the stock rim. Depending on gearing, the bigger tire will have some effect on mpg.
any rubbing on 55s?295/55r22Amp Pro Terrain. I chose them due to them being 6+pounds lighter per tire than others that size, and they are not mid terrains.
How much of a MGP hit did you take?The .5” narrower will likely look odd on the stock rim. Depending on gearing, the bigger tire will have some effect on mpg.
Looking good !!!The .5” narrower will likely look odd on the stock rim. Depending on gearing, the bigger tire will have some effect on mpg.
