cable
bill
Looking for info on getting the LVDS cable that goes between display and module 12.1.
I believe all LVDS runs on 100 Ohm differential... regardless of speed grade.
Not knowing what speed the display module uses, if you got the highest speed grade you could find, in a similar length, you should be good to go provided connector and pinout are replicated.
thank you so much.
Keep in mind idk anything about the OEM implementation; I'm just making general comments about LVDS cables.
