2025 1500 Traffic Sign Recognition
txdenny
Hey all, just bought a new 2025 Ram 1500 night edition with level 2 equipment group.. On the Ram website is says the truck will display the current traffic sign (speed limit) but I am unable to find where to turn it on. Cant find anything in the manual either.. Anyone else have this issue?
It's not going to "see" the signs. It uses map data. You might check in the map settings to see if it is in there.
You have to have the traffic sign recognition feature, and you don’t get that until at least a Laramie with advanced safety group.
If you use Apple Maps, it will show the correct speed limit sign only when navigating.
It pops up in my 25 rebel - unsure if it's the same thing or not
I don't believe that is true (but I could be wrong). I think the new system in the 25's reads the signs with one of the front camera systems.
My 24' used map data and was slow to change and sometimes never changed depending on where I was. My 25' changes right when I approach a sign, and if I enter road construction it actually places an orange bar under the speed limit sign when it sees an orange road construction sign.
It’s in the center stack under the map settings If I remember right. But it is definitely in the center stack settings because that’s where I turned mine on at in my 25
