2024 Ram Remote start programming
Sureshot
Okay I have a 2024 Ram tradesman I’m wanting to activate my remote start !
I have downloaded the Alfa OBD app
I purchased the OBDlinkMX+obdll
I have purchased a remote start key that was recommended
I have a factory hood ajar sensor that came with truck already
I am curious what else am I needing to program my truck to turn on factory Remote start. And do I need the security bypass cables to make this happen. Can anyone send me step by step instructions,On how to do this? I’ve seen a lot of people tagging @Jimmy07 and was wondering if he is who could help me thanks.
That’s the behavior when the gateway is not bypassed. Do you have a bypass installed when making that change?
As noted above you will need a security gateway bypass cable and it will need to be installed. Once installed, you will connect your MX+ to the OBD II port on the end of the security bypass cable.
The security gateway is preventing you from writing/making changes to the various modules you are trying to program/modify.
BlueHemi1500
BlueHemi1500
I did not have the any security cables I will order some try this again next , thanks
OK I have a new problem. I did the bypass cables change the settings under car figurations with the remote start present, I clicked yes it changed, to yes now I have all these. Warning lights on. What happened and how do I fix. Thanks IMG_5097.jpeg
OK I have a new problem. I did the bypass cables change the settings under car figurations with the remote start present, I clicked yes it changed, to yes now I have all these. Warning lights on. What happened and how do I fix. Thanks View attachment 192926
Did you plug everything back in? Is that the only setting you changed? Try disconnecting the battery and see if it all resets. If not, take it to your dealer but don't mention you did anything with the programming.
That is the only thing that I changed, and everything is plugged back in I will try the unplugging battery and see if that fixes the issue thanks.
