The rake is built in for aerodynamics. Air ride raises and lowers with the same rake. You have to modify one way or another to level.Doesn't your air ride level it up? So the front shock is part of the airbag? How many miles do you have?
What was the cost of replacing those shocks? If u don't mind me asking. Just want to figure out a ball park before I get to that point. Tia.I just replaced mine. I used OEM in the rear as I prefer the soft ride of them. Very easy to install. I also replaced the fronts. The airbag and shock are one unit. It’s a lot of work but I also put on spacers to level it.
I’m curious about this as well. Wonder if it’s an OEM air bag with a Bilstein 4600Anyone know what the difference is on these full assemblies? They all say they fit my 2019 RAM but one is $1200 (which looks like it has the Bilstein installed) and then another half the price (which is still available on other sites) but the strut looks different?
my laramie had stock they most definitely were not 4600's and at 72k they were long in the tooth. i replaced them with 4600's it's much better.I’m curious about this as well. Wonder if it’s an OEM air bag with a Bilstein 4600
