2020 Limited 1500
Andrew2024
Hey there. I purchased a 2020 Ram Limited night edition. The grill and headlights are busted. Having trouble finding a used grill and headlights. Can the grill and headlights be switched to another trim level that would look good and be easier to locate used?
No, not without changing some other stuff. The lower portion under the lights needs changed. And the wiring would need to be adapted. Then you'd probably need to change the programming because of the adaptive headlights.
Does anybody knows exactly what needs to be Programmed?
I have a 2019 Limited with the Same Problem. Changed to Aftermarket headlights with No adaptive lights
Just to correct the OP, for 2020 there was no Night Edition available. It was called the Blackout package. The main difference being that with that package you could only get the truck in black. Ask me how I know LOL.
You probably should have made your own thread for this question. Your issue is not related to what this thread is about. The OP was wanting to replace with Mopar headlights not aftermarket. If you're having issues getting your aftermarket headlights to work you might want to contact the manufacturer of the headlights you purchased to see what you need to do to get them to work in your Limited. Also, pics never hurt whenever you're asking for help with something.
He did make his own thread and then cross posted into this one.
Post #60 and 106 info regarding headlights
I found acouple grills on eBay but not black for the limited that is going to be hard to track down.
I’m not sure what you mean by the grill and headlights being “busted” but you could respray the grill (auto body shop) or buy the non-blackout grille and have it wrapped and sprayed also.
Just my .02 and trying to help.
