2025 Ram 1500 Laramie Brake Failure at 2k miles
smb058
On my way home from work a month ago, my 2025 RAM 1500 Laramie with 2,600 miles had a serious brake failure that resulted in loss of all brake fluid and all brake capabilities. Towed it to dealership and they have been investigating the cause and found some concerning results. Apparently, two brass washers on the front left brake hose/caliper failed causing the leak. I was told that there were 6 other identical failures recently, and Stellantis is "reengineering the part". 68674679AA is what they are looking for.
Is anyone else part of those 6 failures? No recall yet, but that was a serious failure that could have resulted in major injury or fatality, so I got an identical trade in rather than having a newly reengineered part on my brake system. Very interested to see where this one goes...
Man, I've been getting brake system failure notifications on my radio recently. I haven't had any issues yet, but this scares me.
What was your build date? I have a big horn would that be the same /system?
I am not sure what the build date was, but I purchased new off the lot in August. From what I gathered by talking with the dealership and pulling teeth working with Stellantis, the 2025 Limited has the same part number. I considered upgrading when I did the trade in, but when they told me it was the same part number as the one that failed, so I decided not to go that route. So, it's likely that the big horn has it too...
I don't recall getting a brake system failure notification on mine. The first warning I got was the "BRAKE" warning on the instrument cluster. It cancelled all driving assist functions (cruise, traction control, active lane management). That alarm can either be from low brake fluid (which was the case for me), or an issue with parking brake. I definitely would treat any brake warning with a high sense of urgency after what I went through
What did you trade for?
I traded in as an identical swap (2025 RAM 1500 Laramie). They basically took the broken truck and gave me a replacement (the dealership was a huge help making this happen). Not ideal, but I wasn't left with many options since it never technically met lemon law requirements...
Do you happen to have a vin for your prior truck? We can find the build date through the bin decoder.
Honestly, Kudos to your dealer for making that happen.
Yea we can get an idea of what line of trucks this issue was with
Build date is typically on the driver side door jamb -- not on build sheet
I think…and someone can correct me…. The build date is on the sticker near the bottom directly under where it says S.L.
I believe that’s MM/DD
I could be wrong.
I could be wrong.
It’s strange because they have month hour date and then a different build date on the top of the sticker
