5 inch air suspension lift
Well mine should arrive before the end of the week and installed shortly afterwards. I will get pictures posted after it’s done.
Did your kit show up? I'm pumped to hear how the install goes!
what does the size of the wheel have anything to do with the lift
Most likely due to the lift spindles. Anything less than a 20" wheel with proper backspacing won't clear them.
ksn240
that makes sense
I can't believe noone has jumped on this yet
Correct me if I'm wrong here, but AWD is not the same as 4wd. On the website below all that stuff (which is important) Under the fitment section, it says 2019 4wd.
There’s no such thing as an AWD Ram.
Hard to tell from pictures but does the 5" kit retain the factor rake? It looks like it's raked in the pics. Great looking truck btw
Thank you. It does retain the factory rake. I like it better. It almost has a raptor/trophy truck look to it w the rake and the large tires.
