SOLVED - Seriously struggling with 5" -> 8.4 upgrade :-/
wmv7766
Hello. I'm having issues upgrading from a 5" to 8.4" screen so I'm hoping you guys have some ideas. First thing I want to point out is I bought two of the same (very similar) 8.4 screen + bezel setups, from different sellers, and the issues are identical. I only bought one radio module though so that's a common denominator.
My truck: 2022 1500 BigHorn with base model 5" screen and basic manual hvac.
First radio Seller's truck and radio: 2022 Laramie 8.4 nav, disassociated screen, single zone bezel w/heated+cool seats, heated steering, two buttons related to traction. *This is the truck that the radio module comes from.
Second radio Seller's truck and radio: unknown truck, 8.4 disassociated screen, single zone bezel. No radio module, only screen + bezel.
Nothing works. The problems happen with both the screen and the bezel controls.
Screen symptoms (applies to both 8.4 screens)
1. No touch response AT ALL
2. Radio locked message, as expected, however the keypad is greyed out anyways and touchscreen does not work anyways, so cant type in the unlock code.
Bezel problems (applies to both 8.4 bezels)
1. Defrost stuck on
2. Full blast stuck on
3. Buttons do not function at all
4. The ONLY button that functions is the emergency blinker.
Interesting details:
1. Turning the hvac airflow knob makes an airflow control popup on the 8.4 screens, however the airflow setting does not actually change as the knob is turned (defrost remains on full blast)
2. Plugging my old 5" bezel in works fine. My old bezel controls function as expected and the settings that pop on screen change as I hit bezel buttons and turn bezel knobs.
3. AlfaOBD test shows both 8.4 bezels as incorrectly having every button "PRESSED". If I press one then AlfaOBD says it is "NOT PRESSED". On the other hand, AlfaOBD shows my old bezel as correctly having every button "NOT PRESSED", unless I press one.
4. I changed the DCSD (disassociated screen) setting in Alfaobd to "Enable".
5. I tested changing the alfaobd setting "Integrated ICS" to disable but then the bezel/hvac just does nothing. No controls popup on screen, bezel controls do nothing at all, defrost is no longer stuck as nothing at all functions.
6. The consistent item across the two setups is the radio module itself.
7. I have tried two LVDS screen cables that were marketed as RAM Uconnect 5 compatible.
I have attached a pic of what the 8.4 screens show at all times.
Any suggestions?
I don’t think the lvds cable is the issue. When I had the wrong one the screen wouldn’t even turn on. Not sure of the touch screen issue. The ICS setting I think is just for the 12.1”. Did your truck have separate temp controls for driver and passenger? You said basic, and you said single zone, but the pic looks to be dual zone, maybe there is a setting for that?
I just replaced my 5" to a 8.4 screen non nav, non heated seats everything works except button controls on steeeing wheel. Im not sure if i have to use alfa obd or jscan to enable?
1. Defrost stuck on
Any suggestions?
Issue is the screen is from a 2019-2021 truck. You need a screen from a 2022+ truck
Another option is to go with an aftermarket radio that has idatalink, and buy the idatalink module. idatalink is a replacement for your OEM controls. Possibly less expensive that buying another OEM radio.
Thanks for the replies. Good news, my issues are solved!!
For the screen issue, Apparently there IS a difference between LVDS cables. They look identical but somehow they are not. I thought I had tried the one marketed for Uconnect 5 already but I was wrong, I had only tried two "regular" LVDS cables. It turns out that the uconnect 5 cable had not arrived in the mail yet. I now have it and the screen works perfectly 🥳
For the non responsive hvac bezel and stuck-on defrost, I needed to enable Dual zone temperature control with alfaobd, even though my truck does not have that functionality.
All is well. Thanks everyone!!
Now that my issues are fixed, my steering wheel controls work. My steering wheel controls started working once the touchscreen issue was fixed, which was fixed by buying a LVDS cable marketed for uconnect 5. I believe that the wrong LVDS cable was sending a constant "pressed" type of signal that blocked out all other functions. Is your 8.4 uconnect 5?
Also are there any features on your bezel that your truck does not have? Something might need to be enabled in alfaobd.
Have you changed anything in alfaobd related to upgrading to 8.4?
I have not changed anything in alfaobd yet. I hooked up everything except the satelite had to get a fakra z cable for that . Everything else works except steering buttons for stereo and phone im not sure if mine is a ucon4 or 5 . Its a my22 . The bezel has no other features has same as old one , no heated seats or anything
Your truck is 2022, do you know what year the radio came from?
Is the radio module separate from the screen (disassociated screen) or is it all one piece?
On the back of the radio module, is there one large black plug or two main square plugs of blue and green?
the radio came out of a 2020 ram 3500 bh . One large black plug. Everything hooked up except satelite until i the cable and now satelite works.
Have not had any luck with the steering wheel radio controls yet . Have not seen any threads with same issue. Will alfa be able to enable steering wheel controls ?
No, there is nothing that gets enabled for steering wheel controls- if they are installed they will just work. I’m guessing the issue might be the radio from the heavy duty ram might be looking for different messages from the steering wheel buttons. Try a radio that comes from a 1500.
Ok ill try that . Its a radio out of a 2020 Ram 3500. Thx Jimmy07
