I need configuration advice?? ORP and Air Ride???
robbiele
I am looking to order a longhorn with off road package. I am also interested in the air suspension. I saw someone referring to the air suspension leveling the truck. Does air suspension level the truck? My other question is should I option a truck with both off road group and air suspension or does it make sense to have both? (I understand ORP adds more options other than just the 1" lift) THANKS
Gondul
Florida
It 'levels' the truck based on weight in the bed or if you are hauling a trailer. It does not 'level' the truck like a leveling kit if that is what you are asking.
I have both the ORP and Air suspension... I think it rides just fine.
Edwards
TX
I've got both and love it. The ORP is a great value, especially if you plan to keep the Falkens on it. I thought I'd give them a try vs. immediately replacing them and have been pleasantly surprised with them.
I wish my Aero height were lower but think I like the 4 position AS better than 5. Less to think about. You may have read it elsewhere, but the ORP lowest and highest positions are identical to a non-ORP AS truck. The programming is just changed to eliminate one intermediate position and remap the other two (Aero & Normal) to 1" higher than the non-ORP model. Rides great and I can offroad as much as I need to and still fit into the parking garage at the airport.
Oh, and the Entry/Exit mode from the keyfob is awesome when loading 80# bags in the bed!
cruz-in
Love my LongHorn with Air suspension and ORP. Although ORP does add weight, decreasing payload. Somewhare I read about 150 pounds. Not sure if that is accurate.
I too was surprised at how the Falken Tires did on the road. Thought I would be replacing them, but think I will hang onto them for awhile.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Amen to that. It still surprises me (and everyone else) how low the truck gets when you hit that button. Makes a huge difference. You have to make sure you're not too close to a curb, as those side steps deploy pretty low!
robbiele
I don't intend to take the truck off road. However, I would like to put at least 34" tires on it. So, should I just not get the ORP and get air suspension?
Electrical
Does ORP cause Aero to be higher, compared to Aero in a non-ORP truck?
S
Smashy71
Guest
I’m biased. Airride is the shlt. I tow and hauled a decent amount and I cannot imagine not having it now that I have it.
Electrical
Yes, 1" higher. I can't figure out the logic there. IIRC, it makes E/E to Aero a 2.5" difference.
Yeah something odd is happening. In addition to Aero is it also true that ORP causes E/E to be higher, compared to E/E in a non-ORP truck?
SpeedyV
Ram Connoisseur
Fort Worth, Texas
There would be no need for that, if indeed the height increase is simply due to a programming adjustment to set Normal 1” higher. If that is true, then there’s no reason E/E can’t be just as low as a non-ORG air truck. I guess I’ll have to go measure at some point...
Electrical
Sounds right, Speedy. But what I'm trying to get at is why the [3.21 axle + eLocker] is only available with a suspension lift.
If something is causing [3.21 axle + eLocker] to require a lift, then how is it that this setup can drop to E/E which is as low as any other truck. Or is that not true?
I'd hate to think the [3.21 axle + eLocker] has a different E/E height than a [3.92 axle + eLocker] truck. I mean this is already complicated enough.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Are you referring to the online configurator? Because we know it’s had many, many errors over the past year.
Electrical
The online configurator, the feature guide, and two dealerships have been unable to configure [3.21 + eLocker] unless I get the ORG lifted suspension.
Edwards
TX
No. I measured my running board heights to a non-ORP AS and E/E and max height was the same. Also, E/E is on the rear bump stops on my truck. It can't go any lower. No idea if non-ORP AS trucks have different bump stops but I doubt it.
Electrical
Thank you. Is this picture right then... all settings for ORG trucks are higher... except E/E?
I see you have 3.92... but I'd assume a 3.21 with ORG would also lower to this same E/E height. So why in the world does it need a raised ride height??
Confused about that. Maybe related to why Aero is higher...?
2019-01-19 21_53_51-Ram Order Notes.docx - Microsoft Word non-commercial use.png
Edwards
TX
Yes, except max height is the same. The lowest and highest positions are the same, just the intermediate ones are higher.
ORG vs. Non
E/E = same
Aero = 1" higher
Normal = 1" higher
OR = OR2 (same)
There is no OR2 on ORG trucks but due to the remapping Normal = OR1 height and OR = OR2.
Webbd30
Are you running aftermarket wheels and tires? if so what size? I ordered this package and want to go as big as possible on that set up
