Tazer DT on 2025 Limited
LOWRMPG
I'm assuming the Tazer DT will work on my 2025, anyone actually use this on a 2025?
Well that is interesting since Tazer told me it would work....wondering if anyone tried it yet.
I'd be really surprised. I'm interested to hear if it would then.
Right. I have the Tazer on my JLU and it works great, was hoping to find something for the Ram so I can do tires and other things.
Tazer said a full refund if it doesn't work, so I ordered it. Guess we'll know shortly.
Please keep us posted.
Tazer can’t work on a 2025. First problem is, it needs to plug into the security gateway module connectors, which are completely different on a 2025.
All the commemts that the 2025 is different makes me wonder how many new modules were implemented in 2025 and if that's the reason for problems. As I recall, the star can bus in previous models (interconnect board with multiple modules connected) was only allowed in LS CAN 125kbps. I believe bypassing the gateway was simply plugging into the star network with a low speed adapter. If all the modules were upgraded to CANFD, then the bus can be much higher speed with encrypted traffic and designed with cybersecurity in mind. Also the only way into the bus is by serial insertion (no star in CANFD). If this is the case, good luck to anyone trying to hack the bus. 2024 may be the last year for adding features after the truck was built.
Yep, you have it correct about CANFD.
Official word in, Tazer DT will not work on 2025's per the Engineers at the company. Looks like I'm off to find another way to adjust tires :)
