Thanks for the photo.
It looks like the splines are chamfered significantly in a radial direction, but not at all circumferential (which would bear the transmission torque load). So the spline shoulders could be plowing a bit of a ridge into the corresponding splines inside the mating part.
Also, I see some circumferential marks near the left end, and I can't tell if they are just machining marks, or wear marks from contact with something inside the mating part.
So these are clues, maybe, and the other end of this spline may have clues, and of course the mating part (which will be harder to image) may have clues.
