All Digital Cluster Upgrade
Foxe
I have a 2022 Ram 1500 with UConnect 5. I was wondering what options there were for upgrading to a fully digital cluster? I've seen info about the cluster supporting maps/nav which would be a great feature to have.
Through my basic research I've found the only things really necessary are a UConnect 5 system since it has an ethernet port to connect to the cluster and provide nav. As for parts, I simply don't know where to start...😅
The best I could find was this link which doesn't seem to support my 1500 Big Horn configuration: 2019-2022 RAM 2500/3500 12" Full Digital Limited Cluster Complete Upgr
There is info on here about it already. Just be prepared to spend a lot of money to get the cluster. I'm not sure if it is still the case, but it was very difficult to find anyone to sell it to you.
Here’s everything you need to know about swapping the digital cluster into your truck:
Thank you so much for the info! I greatly appreciate it.
No, you can’t use a 2500/3500 cluster in a 1500
i found a 1500 sport cluster from Canada. Did the swap today. Now I’m running into the issue it’s not showing prnd or current gear. Also torque and hp units are in kw and nm. Not worried so much about that. @Jimmy07 can you shed any light on this. My truck is a 2020 and I still have the original bcm in. I do have a uc5 radio but not sure out of what year.
I have a 2020 limited 1500, just found a cluster for 1k, wondering if there’s any changes on how to install it? Guys from infotainment selling clusters for 3k already programmed, who knows how they do it? Just don’t want to overpay I guess
See post number 3. There is all the info you will need.
I have my PRND working on a 2020 model with a 2022 BCM flash and a 2026 DT UC5 module for the maps in the cluster.
I had a brand new 2023 BCM installed by the dealer and a 2024 UC5 module and it did not worked for me.
Try making this change in AlfaOBD and see what happens.
But you also have my canbus module installed correct ?
Thanks
Just got done on phase 1 on the 12" cluster, so far so good other than phase 2 of a module. I found a company that will update the mileage on these digital clusters, $600 was the quote. That will be phase 3 only if I like it enough... I have a longhorn faceplate version so if anyone got a Limited one and wants to swap hit me up as those are around $150 new plus tax and shipping, just another expense to add to this project like to avoid.
Does anybody know where to go to change the mileage on the cluster if you could do it from the alpha OBD app I have a 2020 ram 1500
Try this company, they do this for most OEM's.
Any confirmed cases where someone shipped in their cluster? time frame and costs? I found another company that I confirmed with on abilities and cost which I will share if I choose them and feedback as they do not promote the services but are a known oem upgrade solution retailer similar to the info one. I want to be sure they can before promoting, so interested in this source as well before deciding.
