Towing with 2023 1500 Big Horn Super Crew 5.7L eTorque 3.21 axle
rbauer
I am looking at a 2024 Dutchmen Kodiak Ultra-Lite 242RBSL with a dry weight around 5117 pounds. It is 26 feet long + 3 feet for hitch. I want to tow from Colorado to Florida. I am looking for advice if anyone has towed with a similar setup. Should I go lighter and shorter, or am I fine? Thank you.
towed similar size trailer with my '19 laramie 1500 4x4 ccsb 5.7 3.92 with no trouble. our trailer was 6000# and 28' when ready to travel. I got 8.5-10 mpg if I stayed under 70. usually 68/69. towed from DFW to woodland park, co. and back and from DFW to custer, s.d. and back. no problem. many trips around Texas and OK. added air bags and Helwig sway bar to stiffen up rear end when towing. be sure to use tow/haul and get a WDH. add a few # air to tires when towing. if you have oem trailer brake controller, I think 5.5 or 6 worked fine for me.
The short answer is that you are within limits.
The long answer can be found in various towing threads.
As stated above, your tire pressures, need for a WDH and making sure you don't sag too much will be important.
Don't speed or put a bunch of stuff in the bed of the truck as your payload rating (check the yellow sticker on drivers door jamb) is low on RAM 1500's.
Lots more do's and don'ts but it's within your truck's ability.
My 2 cents....tongue weight will affect you well before you hit the max weight the truck can pull. Check that payload sticker in the door jamb, add up all the "stuff" you put in the truck plus the trailer tongue weight and see where you are compared to the payload capacity listed on the sticker.
I agree with the other posts, only thing I would add is to change out the tires to a Light Truck tire. You dont need to go crazy with a D or E rated tire, IMO a good XL is fine, as long as the side walls are stiffer. Once you are all loaded, you will notice the difference, no more "squishy" feeling and a lot more planted. Your trailer is perfect for the TV you have.
We have the same truck, but our camper trailer is only about 3,000 lbs. I still notice some bounce in the rear, and some but not much fishing.
We had the RAM brake controller installed, brake controller is required with trailer over 3,000 lbs in Florida. Be sure that they also perform the console programming that integrates into the RAM.
