2025 RAM 1500 gateway security module location???
jmr
STL, MO
Does anyone know where the 2025 RAM 1500 gateway security module is located ?
I looked and it's not where it was for my 2023 Laramie.
I've heard that for 2025 making changes might be a problem with Alfaobd.
Making changes isn't a problem, it's an impossibility. The canbus is encrypted. Until someome breaks the encryption, it's impossible with AlfaOBD.
I wonder how companies like Infotainment and Z automotive will deal with the new architecture.
I also wanted to enabled the security alarm since Rebel Level 1 Equipment Group doesn't include it.
It does have remote start so maybe I could have the dealer add option code LSA (Security Alarm) to my vehicle config.
I hope someone will come out with something soon. I wanted to do the dropout for fogs and also change the day time running lights to the fogs.(I believe we could do that with previous models)
Was also looking for an option to change out the taillights to LED's and buy some factory taillights.
The Jeep (Cherokee?) has had this encrypted canbus for awhile and still nothing.
You are right, my wife's 23 Grand Cherokee is locked and I haven't heard any news about anybody doing anything for that one.
Now I wish I would have went with the 2024 Hemi haha. I love mods!
I wouldn’t say “encrypted” is the right word for it. It’s just a different configuration, same as 2014-2023 Jeep Cherokee, Jeep renegade, wagoneer, Ram ProMaster, etc. It uses a Proxi configuration instead of a PowerNet config like we’re used to seeing (powernet uses a different message ID for each section of settings like VehConfig 1,2,3…, whereas proxi uses one message ID for the whole bcm configuration). If you check out the car configuration change section in alfaobd for a KL jeep Cherokee, you’ll see how the settings structure is different.
This isn’t a challenge for alfaobd to set up, it’s just the security gateway is more complicated now. There are no star can junction blocks that all the modules all tie together through anymore, they are all daisy chained together on several different buses, and all go through that gateway now.
And it’s not like you can just tap into the can wires that the BCM is on to bypass and make the changes, because after the changes are made, a proxi alignment procedure needs to be performed, which requires connecting to, and aligning each individual module.
Dang, as usual, you have all the answers. Now I see why it is so complicated for the Comma. I'm going to copy this a post it in our Discord and pin it. Thank you!
A couple of years ago I enabled the factory security alarm on my wife's 2019 Jeep KL Cherokee using Alfaobd.
The security alarm worked after making the change but the dash lit up like a Christmas tree and I could not clear it.
I took it to the dealer where they performed a "proxy alignment procedure" and that remedied the dash light issue.
Luckily for me the security alarm was still enabled and worked even after the dealer did the "proxi alignment procedure".
I found a YT Video where the 2 lead engineers that worked on the 2025 RAM DT discuss the changes and the new "Atlantis High" electrical architecture see it at 7:38.
Just traded up to a 2025 ORP and love the truck, but now my plans to throw on Bilsteins w tires and reprogram the new diameter may have to shift. On my last 5th gen Hemi Ram my dealer was not able/willing to reprogram tire size, I believe they weren't able to do so for the 2" Mopar lift and the 285's they installed for me, so I just learned how to use AlfaOBD.
Has anyone heard if the dealerships have capability to reprogram tire sizes for the 2025 1500?
I'm not sure the dealer can. Any options are driven by 3 digit sales code that are applied to your vin.
They can only apply the sales code if your trim level/model would have been a option for it initially.
The dealer is very limited as to what can be enabled on your vehicle.
For me I would like to have them add sales code LSA to my vin to enable the security alarm.
Aside from the issues did anyone answer the question of where it's located?
Does anyone have any ideas? I want to activate the rear fog light output. I've heard that if you buy an OBD splitter, one that plugs into the original OBD port and splits into two separate ports, then when you connect a Witech 2.0 and open the SGW gateway, you can connect another program, such as CDA6, to the second OBD port and connect to the modules. I haven't tested this yet, but has anyone tried? Then two programs are running: one to open the SGW gateway and the other to change the BCM configuration, e.g., Alfa OBD or CDA 6.
On a 2025+? Not happening any time soon.
pretty simple, they don't want owners messing with the truck and made it as difficult as they could if not impossible.
so they made everything dealer level and now the dealer tech's suc and can't even fix them it's a bad joke.
I know two people who managed to bypass the SGW security and make changes to the BCM. Unfortunately, they won't say how they did it. I know that the same problem exists in the 2022 Jeep WL, and I know that there are also people who can connect to the BCM and make changes. And it's the same system with proxy security.
They won't say because you need dealer level tools to do it. You can make the changes in the BCM, but then you need to run a proxy alignment. Unless you have a lot of money, you can't do it like before.
But you can probably create a proxy using Witech 2.0 Aftermarket. But you can't make changes to the BCM through Witech 2.0. That's why I know they use a dual OBD cable. They plug the MDP or Autel head into one port and, with a license, open the SGW. They connect another program, such as CDA or AlfaOBD, through the second OBD port, make changes to the BCM, and then Witech Aftermarket performs the proxy procedure. I believe it can be done this way, but I haven't tried it yet.
