SO Hurricane at drag strip
How does that compare with a Hemi in the same trim?
I’m not familiar with 1/8 mile times. All the strips around here are 1/4 mile only.
For reference, the fastest I ever went with my 2020 Hemi was a 9.3.
He's at 8.9 now. That would be a low 14 sec 1/4 time.
Not bad for a heavy truck
What gears are in that truck?
3.21 will be faster for a roll or top end pull from highway speeds, 3.92 will be better from a launch. There is no free lunch in rear gearing you either give up low end or top end. Can’t have both.
This. Unless you put huge tires then your final drive ratio is lower
