OldMarine
- Feb 29, 2020
What was the purpose of replacing the rotors?Decided to do front rotors...these are my front brake pads after 60,000 miles! These things will go to 100,000 I think. Wow ..
could feel a little bit of pulsating now and then(warpage). Factory recommends tey be replaced anyway at or before 70K miles. Went with NAPA adaptive (their best) at $114 ea.What was the purpose of replacing the rotors?
every other vehicle I've owned in my 66 years, I would have been on my 3rd set by now.Just checked mine while, rotating the tires, @ 70k miles and I think mine might have a touch more pad than that. So I agree, they'll probably go 100k.![]()
At 60K miles I want new rotors anyway...Did you try bedding the brakes to eliminate the pulsation? Many times, the rotor isn't warped, but imprinted with pad material that burned in on a sudden stop or very hot rotor.
You could be right, I might be thinking of a different vehicle I've had in the past. It doesn't matter to me. I could feel the rotors starting to act up here and there, so it's piece of mind for me. Since I save a ton doing my own work I don't mind.I have never seen that in any recommended service from Ram. Inspect brake linings yes, not replace rotors.
![20240824_104728[1].jpg 20240824_104728[1].jpg](https://5thgenrams.com/community/data/attachments/188/188524-9b9e982cb2b0d6ba6ea2b19ed4559b6b.jpg?hash=m56YLLKw1r)
![20240824_104740[1].jpg 20240824_104740[1].jpg](https://5thgenrams.com/community/data/attachments/188/188525-14c0b2c0b9d53c8b749045f044ca3022.jpg?hash=FMCywLnVPI)
![20240824_112634[1].jpg 20240824_112634[1].jpg](https://5thgenrams.com/community/data/attachments/188/188527-e090531ebf20a4a7af73499ec7091508.jpg?hash=4JBTHr8gpK)
Pretty sure all the 5th gen`s.Is it just the etorque setups that are getting the long brake pad life or all 5th gen?
I am from Canada I have Over 240,000 km on mine and still have lots of like mine is just the regular hemi no etorquePretty sure all the 5th gen`s.
Did you ever determine what was causing the squeak? Just in the past couple of days, my brakes have started a light squeal when the brakes are cold and I was thinking a pad replacement might be in order.I started getting a squeak on light brake application. I pulled the calipers and checked mine today at 130k miles.
Fronts: Still had a ton of pad left. Rotor thickness 30mm (28.4 min thickness).
Rears: The outside pad was worn slightly more, so I flipped the pads. Rotor thickness measured 21.5mm (20.4mm min thickness)
I've never seen brakes wear this well. I'm impressed.
View attachment 188522View attachment 188523View attachment 188525
