Power deployable steps controlled by key fob
Smitty0806
Everyone,
I have a 2025 Ram Limited 1500. When i purchased it the boards would deploy only when I opened the doors. I have changed some settings and profile info and now when I unlock with the key fob the steps on both sides come out regardless of whether the doors are opened. Anyone know how to stop this and to make them only come down when I open the doors? There are a lot of wasted cycles with the passenger side deploying and retracting every time.
First you might read through the owner's manual and see if there is a setting for that. There are quite a few changes for 2025. If not it might be worth trying a reset of your uconnect. But it's a brand new truck. Take it in and have it looked at by your dealership. That's not something I've read anyone else having an issue with here.
Thank you. I am going to try a reset back to defaults and see if that does it.
That is interesting…. not sure if I like that…or would have issues with it.
I think I’d like it.. coming from a truck that previously had fixed side steps, I always seem to catch them when they’re deploying down, I have a feeling I’d like that better.
Before going back to the dealership, I’d dig through settings, I’d bet you can find something about auto deploy on unlock or opening of doors. Probably in safety features sub menu.
Everyone,
just had some installed on my 2025 ram and im having the same issue. Did you ever find a solution?
I just bought my new 2025 ram limited 3 days ago and now it’s going that same thing. When I unlocked the car from distance the power steps deployed. Has anyone found a solution? I might have to take it to the dealer. Currently right now it’s in store mode not auto because I don’t want them deploying.
Everyone,
Mine, 2025 limited, was doing similar.
I would walk by the truck with fob in pocket and step would deploy!
Dealer did update and all is well now.
Paul B
That's what it's supposed to do. It's programmed that way. I'm not sure you can turn it off though. Mine deploy when I unlock and if there is no passenger, it retracts before I can close my door.
I don't remember the exact setting but there is a setting in the uconnect called proximity lights or something of the sort this is not indicative that it would affect the power steps but it also controls the steps deploying when you get near or unlocked with the fob.
