Squeaky Brake Pedal = Install new assembly: Anyone?
MishMashRAM1500
2021 RAM 1500 DT Big Horn - Brake pedal squeaks more than a mouse. Got down under there and realized one of the moving parts, a pivot with a plastic collar, has cracked. I spray silicone lube on it and it resolves it for a time but only for.
I bought a brand new pedal assembly. Has anyone installed one of these before? Any tips or gotchas?
Yep I have the squeak and so far the last lube I used is still holding up.
Ok thanks for the reply! I guess i better get into it and replace it. Before I do, I may upgrade the assembly with brass bushings or some such to prevent it from happening again
