110v Inverter fuse or disable?
brdima
2019 Ram. I need to disable or turn off the 110v inverter that's factory installed. What is the best way? Fuse? If it's a fuse, where would it be located? Google failed me.
I’m showing this one on the in cab fuse panel. Why do you need to disable it?
If those are aftermarket LED lights, start there. Lots of people have had strange interference problems with remote start and such and traced it to cheap LED bulbs.
Thanks. Lucky for me all OEM stuff. I’ve traced it down to RFI only when engine is running. Hoping it’s not the coil packs.
In case any hams come looking for same info - the F60 50amp fuse is the correct one to disable the inverter. The inverter doesn’t make any RFI until something is plugged into the 110v outlet. So disabling it didn’t solve my problem, but today the truck wasn’t making the same RFI as the last time I saw it.
Could it possibly be the RF hub? Do you also have FCW or blind spot? To me the coils and engine would generate EMI not RFI
