The buggers! I got nailed the same way. Red light/Speed Cam.
Not just once, but again at another intersection 2 blocks further down the road.
Between the two, It wasn’t cheap!
Let’s just say, I didn’t buy any truck mods for a while!
I have a dash cam now that alerts me of upcoming camera setups.
I thought those were deemed illegal. they disappeared around here after a couple years, disappeared as quickly as they appeared.
It is state by state. Here in GA they were deemed illegal (unconstitutional) and then brought back for school zones only.
I was able to gently stretch the OEM blanket over the bigger battery, but you do have to be very gentle. If you find a source for the larger blanket, please post up. 2500/3500?
I found two part numbers for an OEM battery blanket. 05033397AE and 68494324AA
It appears the 68494324AA is more expensive one, so maybe it's for an H8 battery? I'm not totally sure yet though.
5033397AE is for the H8 bigger battery. I got information from this forum for when I upgrade
We had one in floyd county that was notorious for giving false tickets. Was thankful to see that thing go. The school zones are annoying but I'm mostly okay with it at least.
I am ok with the school zone cameras. Anyone speeding through a school zone deserves what they get.
Georgia law allows speed cameras to be used in school zones to issue speeding tickets to drivers who exceed the speed limit by at least 10 miles per hour. The cameras can be enforced during the school day, one hour before classes start, and one hour after classes end. They can also be used on days when schools are in session, but not on inclement weather days, school holidays, or digital learning days. Some cities, like Warner Robins, may also use the cameras during the summer when schools are hosting classes.
The TRX blanket fits the H8.
I got one from NYC (never been there) for a car I didn't own, with NY plates. One character off from mine, but it looked similar, so they thought it was my plate apparently. I spent weeks calling and sending copies of my insurance cards to get out of a $100 ticket from a place I've never been. :LOL:
@Bo-Bearski been thinking about your AC discharge line design and the gripe on the Dorman elbow fit - so I made a slight mod. Thanks for the inspiration.
2 ft of radiator hose and two zip ties. All in under $2.
5/8 ID was the perfect fit.
This picture above is zip tie #1 w/ slight hose bend towards rear.
Down below the discharge is right level with the bottom of the frame and zip tie #2
So far so good.
While the water wasn’t leaking inside, I did notice some dripping behind the passenger side heat shield and also dripping on the hot exhaust.
Added Dee Zee tie downs in the factory locations near the cab x2, and 4ft black "L Track" tie down rails to the factory hole locations. Ditched the Dee Zee Rivet nut hardware, except for the rivet nut bearings and washers. They are 6 sided, shaped to fit factory holes, but not with a spray liner. Drilled factory holes with a 11/32 bit, tapped in black zinc 6mm rivet nuts in all the hole locations, set them with a boxed end ratcheting 10MM wrench & vise grip pliers. Sat back and enjoyed my accomplishment. Note: none of these are for extreme tie down pressures. The nut zerts are not that strong.
See other photos attached below​
Parts List:
Dee Zee DZ97913 Tie Down Kit RAM 2019+ from amazon
20x-uxcell M6 Rivet Nuts Carbon Steel Zinc-Plated from amazon
2x 2.5"x 6mm class 10.9 (grade 8 equivalent) bolts & 2x 10mm flange nuts from any hardware store
Upgraded the tailgate emblems with carbon fiber overlays, to match the door, hood and grill all ready installed, reflective orange in the ram head.
Here was a local news story about old Iowa live se plates that were supposed to be destroyed showing up on vehicles in NYC and the old Iowa owners getting tickets. Even though the vehicle wasn't even close to the same as what the plate was registered to when it was even a valid plate.
Today I thought I was going to have to make an appointment at the dealer. Truck started running bad at anything above 1/2 throttle and above 3k RPM. No power, and wouldn't shift. Almost seemed like it was hitting a traction control fuel cutoff. Had about 1/4 tank when I first started to notice a slight issue and it got worse as fuel level went down. On a hail Mary before calling dealer, I filled up the tank with some 93 from a station I use regularly, and truck started running better almost immediately. The last time I filled up, I filled up at a station I had sworn off before because they always looked like shady stations you'd get bad gas at. But they have been remodeling all the local ones, and they even got Top Tier designation. So figured I give them a try since they were cheapest option, and top tier. Guess that was a bad jdea. They are back in the do not use list.
Bad gas is the very likely culprit.
But what of your gas filter? Has that ever been changed?
There should never be an occasion to need to change the the filter inside the fuel tank unless you are dumping dirt inside your fuel tank. Fuel pumps, at gas stations, all have filters on them that filter the fuel before going in your tank. Water in the fuel is your biggest concern from a gas station followed by just bad gas in general.
Parts List:
What bedmat is that?
Cool.
But don't you think it even a little odd that the bad gas only presented a problem at 1/4 tank?
