Transfer Case Control Lighting
MLB12
Calgary, Alberta Canada
So, after putting 10,000Km(approximately 6,300 Miles) on my Longhorn, I just realized that the transfer case control isn't lit. I only discovered this last night when I had to shift the transfer case to a different mode, and actually had to turn one of the overhead console lights on so I could see which button to push.
I would have expected that this control would be lit in some way, shape, or form.
Thoughts anybody??
Thoughts anybody??
SHOOT!!!! I just realized that I posted this in the wrong forum. Apologies all around.
ADMIN: Are you able to move it to the correct forum, or how should I handle this??
I don't know if all trim levels are lit but mine is.
The control on my Laramie is lit, I would imagine your Longhorn should definitely be lit. Is it just the lettering on the buttons that is not lit or do you not have the amber indicator light on the selected mode either?
If the dimmer is all the way up, it turns of the transfer case lights.
Interesting, I guess I haven't ever turned the dimmer all the way up, I keep it just below the max detent.
Moved it to interior.
This morning I decided to test this out and found that my truck does not work this way. If the parking lights, headlights, or auto lights are on, the transfer case control lights are on no matter where I have the dimmer. They do not get any brighter than when the dimmer is just below the max detent, but they do stay on when I go to max, they also stay faintly lit if I run the dimmer all the way down. I am not sure if this is how it should work, but it is how mine works. @MLB12 did you confirm whether or not your lights turn on when you lower your dimmer?
I'll have to play with it. I know the transfer case lights were off and when I moved the dimmer off max they went on.
That's what mine does also. If I take it off of Max, all the buttons are lit up.
I really wish the dimmer could be a bit brighter before putting it on Max.
I agree, it is quite a jump from the highest “dim” setting to max. This is interesting though, all of my lights are on all the time if any headlights/parking lights are on, and others turn off completely at max setting. I wonder if this is by design between models or if there is something wrong in the truck software. It would be helpful to know what truck configurations each person has.
No, they don't. I've got an appointment set up with the dealer to see if we can figure out what's going on. I'll keep you posted.
Thanks for your efforts.
For some reason the cup holder light turns off when you select max bright detent also.
I'm not sure why, but it does.
My transfer case lights stay in at max bright detent if my headlights or others are on. I didn't check with headlights off.
