rtm03862iq
Thanks!
All of my research indicates all Ram DT’s use the same UCA across the board. Regardless of trim level. The part numbers I supplied are for Mopar 2” lift and are described as Mopar accessory lift parts.If you have a Rebel or non rebel with the Off road Group you already have the factory 1” lift and which also comes equipped with the Mopar offroad control arms… no need to order the same control arms you’re equipped with unless you need a replacement.
There is no difference in the control arms on a ORP truck compared to a non-ORP truck.If you have a Rebel or non rebel with the Off road Group you already have the factory 1” lift and which also comes equipped with the Mopar offroad control arms… no need to order the same control arms you’re equipped with unless you need a replacement.
