scottmoyer
- Nov 13, 2020
Like many here, I've had a clunk in the front end when going over a speed bump with the wheel turned slightly from center. I didn't worry about it too much before because I ordered the SuspensionMaxx sway bar endlinks. I leveled my truck with Bilstein 5100s, added the sway bar endlinks and replaced the UCA with the Mopar leveling kit UCA. I was hopeful that torqueing to specs and making sure everything was tight would address this. It didn't What else should I look for. It shouldn't be the shock topping out when the wheel drops, but anything is possible.
Also, I get a grinding feel in the floor when turning into a drive and the truck flexes. It feels like worn out metal on metal brake dragging, but it only happens when the wheel is slightly turned and I hit a dip or enter an uneven drive. I can replicate it at speed by swerving the wheel side to side. As the front end dips down on one side or the other, the grind/vibration/rubbing is felt in the floor. Is it the Good Year Duratracs (AT tire) with the rough edge and I'm just feeling the edge of the tread vibration?
Any possible things to look for will not only help me, but possibly others. Thanks
