Tire pressure issue with ram 1500 OEM aluminum wheels?
mtt582
Does anyone have any experience with losing tire pressure without any punctures being in the tire? I took it to the dealer and bought a brand new tire. The new tire is not losing as much pressure as my old one but it is still happening and it’s only going to get worse ( just like the first one). The dealer soaked the tire in solution and said they couldn’t find the source of the leak. That’s as much as they were willing to do. The truck is still under warranty and I know that tires, wheel alignment, and wheel balancing are specifically mentioned as not being covered but this seems like it should be. Am I wrong?
The only time I've had this on another vehicle is due to corrosion on the wheel causing a bad seal on the tire bead. They needed to clean off the corrosion.
My. “
How fast is it leaking down?
Is it the tire that is leaking, could be that he rim casting has a flaw or the valve/stem is leaking.
old” tire was leaking from 39 psi to 22 psi by the end of my 10 hour work day. At night it would drop as low as 13 psi. I just had this new tire put on yesterday and it’s already down 3 psi. I know that’s not a significant amount but it just means a new tire didn’t fix my problem.
I don’t know if all dealership mechanics are like this because this is the first and probably only time I’m buying a car new, but they seem very annoyed when I asked them to do anything past spraying the tire. Like a tire spray test is actually their final solution 🙄. If it wasn’t for the factory warranty I would never step foot in that place again.
take the wheel and tire back to the place you bought it from and have them put it in a tub of water and watch for bubbles
My. “
Way too much of a pressure drop. Take soapy water and a brush to the wheel unit in question, look for bubbles.
Haha that’s what they did and they said they could see where any air was escaping. they literally thought I was making it up till I showed them pictures. I asked them what the next step is and they were clueless so I just bought a new tire. But now the same thing is happening. I’m pretty sure they didn’t test the new tire before they put it on though.
Brother I wish it was that simple.
Take it off the the truck, cover everything with DAWN dish washing soap and watch the bubbles form.
Mix up some soapy water and cover the valve stem. Also remove the valve stem cap. I got my a$$ kicked about 1986 chasing a slow leak that turned out to be a piece of plastic flash depressing the stem when the cap was tightened down. The cap is only to keep dust out, it doesn't seal airtight.
If that doesn't locate it, then go around the beads. Logically, since you had the same leak with old and new tires, it ain't the tire. And while aluminum rims can be porous, I don't think that would start all of a sudden. And if you've already ruled out the valve, that leaves the sealing area. You can get corrosion on the wheel, or the finish will flake, or they used a pound-on wheel weight and it disturbed the sealing surface.
Take it to Discount Tire / American Tire, they can tell you for free what is going on, often fixing it for free. I've had them figure out issues that the dealer couldn't. If they confirm the issue could be a warranty issue, then take it back to the dealership with their suggestions.
On our old Lexus, the chrome on the wheel was causing a leak on the rim. Discount Tire fixed it for free, using some sort of rim tape I think, been good for years. But if they find something similar, the dealership should replace the wheel.
I have a suggestion, take some soapy water and find the leak yourself like the other 12 people said.
Maybe it's not leaking and the 3 psi is due to temperature change, just a thought.
Smh what’s got your panties in a bunch? The forum is for asking questions is it my fault the 8 people gave the same advice to 1 question I asked? Don’t be a tool, that’s free life advice. Now to answer your question that test was already done by 2 technicians at 2 different tires plus, and once at the dealership. I think soap and water works the same no matter where you use it.
In your defense the advise about the temperature change could be valid but I would think that would effect all the tires psi and not just the one.
Now sir, my advice was just recomming what many others had stated, I was supporting their claims of how to find a tire leak. Google can answer many questions.
To answer your original question, no why would you think a tire leak is covered by 3/36.
You purchased a tire for a tire leak, why?
How much air are you down today?
My actual life advice for you, don't park in dangerous places.
My experience, it depends on sunny vs shady. From what I recall 1 psi for each 12 degrees. Got a cold night with a sunny morning, again from what I recall my tires were 2 psi difference on 32 psi tires.
Shady side had grass, sunny side had pavers.
