33x12.5R20 2022 Limited- Looking for help
Dupras
Have a 2022 Limited (without air suspension) and it’s time to swap out the OEM tires. Looking at moving from my 285/45/R22 and getting into 20s for ride comfort and a more meaty AT tire. Would love to hear feedback on getting a set of 33x12.5R20s using 20x9 wheels with a +1 offset without leveling or trimming.
Anyone have this setup and can confirm no rubbing or issues with the UCAs?
Anyone running 33/12.5 R20 on stock suspension with no issues?
i have 20x9 0 offset wheels but 35x12.5r20 in terms of space between uca and tire the 0 or 1+ offset is fine . if your wheels were a 20x9 +18 then yea u would have a problem.
Damn, so you managed to get 35s on there with a 0 offset on stock specs with no rub or trimming?
Gonna need to level
Damn, so you managed to get 35s on there with a 0 offset on stock specs with no rub or trimminG?
i put 35's after i leveled the truck. but prior to the level i had the stock limited wheels 20x9 +18 33x11.5r20 and a they fit just fine.
So if you had the 33x11.5R20 with the stock offset, I should be good with the +1 offset wheel I’m looking at with going 33x12.5. Thanks so much for the help!
here are a few examples to help you decide but i would say yes you should be fine with uca and tire clearance on a 0mm or +1 offset
i went through customoffsets gallery and played around on the site for a while until i could confirm my current tire/wheel setup would work this may help u as well
I thought so. Looks like I can get away with the 33s but for 35s at least a level. Any experience with towing with being leveled?
Just a couple of time, but nothing real heavy (no camper, enclosed trailers). It was fine.
just for reference you can fit both of these stock height. Might need a heat gun for front wheel well liners
