CHeYeNNe71
Oiled is not worth the hassle for the minimum performance over dry performance filter. Also if not cleaned and oiled properly and even then, oiled does let dirt pass.So this may be a surprise to some but the whole idea behind an oiled filter is the ability to have more flow and keep the filtration the same via the oil. So unless you neglect it, there is in no way shape or form it will harm the engine. And nobody on here can provide any insight on it other than just saying it because it's what they've heard.
" Generally, high-performance dry filters can catch up to 99% of the incoming contaminants due to the smaller micron size of the filter media, while oiled filters catch about 98% of what passes through - a minute difference, but a difference none-the-less. "
Minimal, but why even bother. I would never run oiled because it's not worth it. I stick with dry re-useable.
				Air Filters 101: Dry vs. Oiled
Usually, an intake is one of the first ideas that come to mind when someone starts modifying a car...
				I'm sure someone will dispute this as many on here like to dispute until the post ends or their ignored
Have a great evening!!
