Service Electronic Throttle Control and a Long List of Codes
nc_beagle
NC Foothills
I was driving along the highway (not interstate) into the NC mountains. Part way up the mountain, I heard an odd noise in the front, sort of a "donk," followed by the sound of air rushing. My first thought was I'd punctured a tire, but then I started losing power and the dash lit up. First I saw "Service Electronic Throttle Control" and then I think the ABS light came on. The truck slowly made it up the mountain, but I pulled over at an overlook and used my OBD scanner to read the codes.
It threw off a ton of codes, including "Turbo underboost (or something like that)," "Implausible Data Received from TCM," "Torque Request Signal Denied," "Lost Communication with TCM," "ABS Disabled CPU," "Implausible Data Received from Driver Assistance System Module," "Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1," and some others I didn't capture on my screen grab. The transmission/engine started surging and there would be a noticeable noise like air under the hood. I though maybe some sort of vacuum line had broken, though when I looked under the hood (after parking it at my destination) everything looked normal and clean--at least what I could see.
As I got closer to where it's now parked, it began shifting erratically and I could hear a "clunking" noise from what seemed like the rear differential area. I'm about three weeks before my 3/36 warranty expires, though powertrain I know is longer, so I plan to take it to the dealer but I'm curious if anyone here has any thoughts.
I'll add that I've read all the stories about the OEM battery only making it about three years and that all sort of electrical issues can happen when it starts to go. So, I changed the battery, but the problem remains.
I've got about 21K miles, the vast majority being interstate/highway.
reading the "air rushing" part of your post. my first thought would be that the charge pipe may have blown off either end of the intercooler. that's where I would check first. having owned a troublesome first gen RAM ED I was aware at the time of this happening to other owners. as for the plethora of DTC's, any time one of those motors see a problem, it sets a large number of codes downstream from the original problem condition. but charge piping would be the first place I would look..
Good luck. keep us posted.
Thanks, I'm heading back up now and will check it out and will report back.
Assuming I am looking at the right pipes (left and right side of intercooler. At the bottom) they are attached but there is some wiggle play at the connection points. Also where one pipe goes over the engine at the center of the engine bay.
Yup that would do it. The good news is, for the low low cost of a new clamp, you should be back on the road nice and quick. glad it wasn't a blown out end cap on the inter-cooler. that would have been less cheap.
Thanks for your guidance. What would have caused it?
my guess is that the clamp was faulty. as you climbed the mountain, the boost pressure would have been holding steady at an elevated pressure, and the clamp finally gave up. once you replace it, chances are it will never fail again. I'm pleased I was able to point you in the right direction.
cheers!
Well, it happened again. Next clamp up the line.
Must have gotten a bad batch.
Edit: This time was under full boost. I don't think it was last time.
Question for the board. Should I tighten a clamp very tightly? Or do I need to back off a little for expansion?
Just for reference if anyone searches and comes across this topic.
I took it in to have the dealership evaluate the clamps I put on (one I could not get through the hose's "belt loop" because it wouldn't fully open) and to diagnose an odd hum noise that began at partial throttle (RPMs and gear didn't matter) and would get louder if you gave it more throttle.
The dealership reported that the boost tube had failed. But here's what worries me. They said that my aftermarket (name brand) air filter might have let too much air through and led to too much pressure in the tube. I don't remember the brand name of the filter I used but it would have been from a reputable company and was not a K&N filter.
Their comment leads me to think they want to deny a warranty claim, arguing that the filter caused the problem. It's a 2021 EcoDiesel with 22,000 miles.
I am no turbo expert by any means but is it not the waste gate that limits the air charge pressure?
that's a crock. you could run it without ANY filter in it (not recommended lol) and it wouldn't cause an over boost condition that would result in the failure of the charge tubing. There are MAP sensors that monitor the intake manifold pressure that should prevent the turbo from overboosting the engine. that being said, the EGR (exhaust gas recirculation) system tends to pump an abundance of soot into the intake system to appease the enviro dweebs and I cleaned my MAP sensor several times. its possible the MAP sensor is crusted over and and its not properly reading the manifold pressure. good luck. these engines can be a bear when they are having issues.
I picked it up today. I haven't had time to look it up but he said they tried to run it through warranty but this particular part was not part of the power train warranty. That surprises me as it's not really a wear part.
I have a good relationship with the service department so I kind of hope he is correct even though it's money out of my pocket.
