Take it out and see how hard it blowsI have and changed it. No difference
Just posting back 2 months later. I'm still glad I put the K&N cabin filter in. The truck is cooling better, perhaps mostly due to the increased air volume, but better. Both my wife and I noticed it independently. I'd say this moved me into the "acceptable" category for A/C performance, that I don't have any current plans to install the hack.I'll keep monitoring the system and will let ya'll know if I see anything significant. But at the moment, I am glad to have the new filter. Even if it just results in more air flow through the system, it was money well spent.
There really is no need for a HEPA filter in a vehicle.Dealer said it was the filter. I used a Bosch hepa filter. They put the oem in and it does blow a little stronger
That’s misinformation. They wear 3 masks now.
Makes sense. Hepa is thick and will make the blower struggleDealer said it was the filter. I used a Bosch hepa filter. They put the oem in and it does blow a little stronger
While he has the window open, and he has a beard, so it doesn't fit tight to his face.
Doesn’t matter. The appearance of compliance is all they are worried about. The neck gator I wore during the scamdemic just to not be harassed by store employees while shopping was so thin you could see my mouth through it. But I was “following the rules” and “slowing the spread” so everyone was happy.While he has the window open, and he has a beard, so it doesn't fit tight to his face.
i work for a company that manufactures cancer medication in ISO clean rooms. WE use hepa filters. no need to for that in a truck, would need a much bigger fan to get same results as other folks.Dealer said it was the filter. I used a Bosch hepa filter. They put the oem in and it does blow a little stronger
lmaoooooo. wearing a mask outside and their cabin filters plus home filters aint been changed in years.
2020 ram 1500 bighorn. Have had AC issues since purchase. Crappy performance. Just recently have found the sweet spot and AC works flawlessly.....setting to 64! Any other one its crappy. Don't understand why, but it just works.
