Squeaky brake pedal
Insanity
My brake pedal has been squeeking for a while and it's driving me nuts.
I sprayed some of this on all the pivot points I could just now. I'll let it creep in and see if it helps. Has anyone else had this happen and know what part needed some lube?
I have not got under my truck like you have, but this is similar to a noise I have that started one or two months ago. I am close to an oil change, and I am having it checked out.
I’ve searched through tons of threads and you are the only person I believe that has captured/described a noise similar to what I am experiencing.
I do not believe I need to rush to the dealer, but give me a month to six weeks and I will report back after I get my next oil change.
Thanks please let us know what happens.
Mine squeaks a little. Never really think about it with the radio on. Curious to see if this works
That stuff didn't work so I'm trying this. When I work it and side load it I can get the squeek to stop.
My problem was exhaust moving around in bushings, and can't be fixed apparently.
Just got the oil changed, and two techs told me this. I may need to live with the creaking noise.
Sorry I can't be more help this time.
