The_Chemist
- Sep 12, 2018
- Location
- Swatara Township, Pennsylvania
Exactly!I ran out of time trying to install mine yesterday and saw what you are talking about. I have the weld indentions but also have the holes. My issue was that the holes don't line up with the seal. The outer two are fine but the third one in is off by about 1/2".
On top of that, the seal seems designed for a wider bed-to-cab gap than the 2019 has. The side seals don't touch the cab whereas this one will not only touch but be forced to curl in. I'm concerned about grit getting in there and rubbing through the cab paint over time.
Unless I'm doing something very wrong.
I think the design may have been changed. My first hole is close to the side seals. The other holes that I could feel are not drilled through. Where the verticle pieces of sheet metal come together, I can feel a complete hole on the piece of sheet metal that faces the cab. In the center of that hole I can feel an indent, not a hole the entire way through. Therefore, I don't think my seal will not even line up correctly, unless I'm just not seeing or feeling the holes correctly.
I may purchase a cheap fiber optic usb snake camera on Amazon to connect to my phone so that I can get a visual.
I think RAM owes all of us big time for all the hours of time and labor we have in trying to fix noises, squeaks and rattles on our brand new trucks! LOL
