Rambar & multifunction tailgate
darkhorse
I've only seen one other post about this on here from 2 years ago. Basically, I'm wanting to mount the rambar on my 2023 Rebel that has a MFT. I've replaced the brackets already with the ones offered by Right on Bracket, but that won't resolve the issue for mounting the rambar. Could you not make modifications to the rambar by chopping the inside front bracket off and screwing into the bed rail instead? Or chop the new bracket and re-weld to overlap the rambar?
I mean, you can do whatever you think will work. The Rambar isn't load bearing, so it's not like it needs to be bolted on with high grade fasteners
I think I'm going to trim the rambar around where the right-on brackets are located for the MFT.I thought about welding the brackets in place to be part of the ram bar, but I'm honestly not that great at welding and it would probably look better with a bit of trimming, grinding, and some paint.
Well. It worked! Got this done today in the rain. A little trimming with an angle grinder and fits like A charm. I already had the right-on-brackets in place since I needed them for my Retrax MX tonneau cover. I sprayed a bit of textured black paint (from aev) over the exposed metal to help prevent any rust. Turned out pretty good, and my tonneau cover JUST fits between the bolts.
View attachment 183963View attachment 183964View attachment 183965
Great job bro. I have been doing a lot of web crawling looking for this solution for a while now. I just ordered the right-on-brackets so I have a little bit of a project ahead of me. how is it holding up?
No issues that i've seen!
