Diagnose This Tire Wear Issue
I'm thinking the sensor or link on passenger side is not allowing the truck to return to the spot it needs to like the driver side.
Most of the complaints are for wear on outer edges of tires on both sides, kit just one
theblet
a lot of round abouts in your area?
awesomedudekj
Iowa
I can confirm that Ram did not figure this issue out over time, I just rotated my tires on my 2022 Limited with air suspension and the passenger side front tire is the only tire showing this wear. The three others all are wearing normally. I will be due for tires at the end of this year and I plan on having the alignment checked.
E.Hands
Youngsville, Louisiana, USA!
Both front toes out right from the factory.
Strange, the Left was toed in and the right was toed out? Was you steering wheel straight when going straight?
It appears that it is now set very well, slightly negative camber and near zero toe-in. I believe that excessive toe-in causes the very outer edges of out front tires to wear excessively.
Thanks for sharing your experience!
cerbo
TN
believe it or not the wheel was straight. Probably just a factory slopped assembly.
