Diagnose This Tire Wear Issue
I've seen people without air suspension complain about it, but it's mostly the air suspension equipped trucks
I'm thinking the sensor or link on passenger side is not allowing the truck to return to the spot it needs to like the driver side.
Most of the complaints are for wear on outer edges of tires on both sides, kit just one
a lot of round abouts in your area?
I can confirm that Ram did not figure this issue out over time, I just rotated my tires on my 2022 Limited with air suspension and the passenger side front tire is the only tire showing this wear. The three others all are wearing normally. I will be due for tires at the end of this year and I plan on having the alignment checked.
Both front toes out right from the factory.
Strange, the Left was toed in and the right was toed out? Was you steering wheel straight when going straight?
It appears that it is now set very well, slightly negative camber and near zero toe-in. I believe that excessive toe-in causes the very outer edges of out front tires to wear excessively.
Thanks for sharing your experience!
believe it or not the wheel was straight. Probably just a factory slopped assembly.
my 2021 1500 laramie with air suspension has excesive tire wear on the passenger side front tire. the tire is wearing on the outer edge. The dealer checked the alignment and said there is no problem. the tires were rotated and after 7k miles the same wear pattern is showing in that location. The dealer said they would check the alignment at my last oil change recently but the didn't. not happy with the customer service.
I have the same issue on my 22 Big Horn.
I picked up a front-end vibration between 75 and 80 mph. Had to get the wheels rebalanced, and it went away.
Rotate my tires every oil change, and currently have 33,000 miles on the original tires,
