Trooper4
- Feb 14, 2019
- Location
- KITTITAS, Washington
Didn't get it for mpg. Got it for comfort and utility. But, I do pay attention to it with gas closing in on$5.
Must be niceBeen tracking for awhile and just as I expected.
Surprisingly after changing from 32” tires to 34.3” my gas mileage stayed virtually the same.![]()
That image is as optimistic as the Ram display. 2544 miles and 261 gallons is 9.7mpg, is it not? That's about what my Challenger gets but I go through a lot more tires.Must be nice
you know it could be but at this point im done racking my brain about the lame a** gas mileage i get and waiting for the day i get a new truck.That image is as optimistic as the Ram display. 2544 miles and 261 gallons is 9.7mpg, is it not? That's about what my Challenger gets but I go through a lot more tires.
Truck still 100% stock, including tires?Just checking back in on this thread 4 years after I got my Rebel and posted early on.
My mileage has gotten worse; just did a familiar round trip where it would have been easy to see 18mpg, and only saw 16.0. Doesn’t sound like a big difference, but I was ‘trying’ so it should have been, say, 18.5.
If I could keep the truck at 40-45mph, I’d probably see 28-30mpg. It just sucks gas badly at highway speeds. And I’m only talking 65-70mph.
Disappointed.
Only reason mine has dropped is due to modifications. There may be some places still with winter blend fuel that will drop your fuel mileage. Might be time to replace the air filter.Thanks - yes, the truck just turned 25k miles so it’s still on all factory equipment. 5w20, tires at recommended pressures (maybe a touch high due to warmer temps now).
I’d be perfectly happy if I could do 18 highway, but 16 is a bit of a drag.
I got a friend with a similarly equipped BigHorn, and she was disappointed to recently drop from 20 highway to 18.
Still love the truck - 9/10 things are perfect. This is the last piece![]()
I hand calculated one time and it was 1
Mpg lower than the dash. Not worried about fuel mileage anyway
My
Mine too.
For the 1st year I checked the trucks computer mpg against hand calculating, my display was never more than 2-3 tenths one way or the other of hand calc'ing it.
I spot check it now and then and its still the same 420-430 miles per 23 gallons of mixed driving (mainly city). As long as I get a minimum 420 miles per 23 gal, I don't worry about it
same here, very very close . Goes both ways so probably has more to do with the pump and when the pressure shuts s it down. About 200 miles today, highway 65-75, 19.8 MPGs coming and going.Same for both of my Ram trucks. The computer is close enough that I only check every once in a while.
What gear ratio do you have? Curious how much that matters. Seems most posts in this thread with really low MPG have the 3.92.same here, very very close . Goes both ways so probably has more to do with the pump and when the pressure shuts s it down. About 200 miles today, highway 65-75, 19.8 MPGs coming and going.
Let me add, I could probably drive the same trip and get 16 MPGs. Just to say it s hard to compare with others.
Wait.. What? You change the air filter? Aren't they lifetime like the oil filter?Only reason mine has dropped is due to modifications. There may be some places still with winter blend fuel that will drop your fuel mileage. Might be time to replace the air filter.
Run without one. It sounds cooler.Wait.. What? You change the air filter? Aren't they lifetime like the oil filter?
Bet the truck stays cleaner too!You guys need to remove the back seat. Upped my mileage 2 mpg.
Also, as a side benefit, no more annoying kids in the back seat. Looking at taking the passenger seat out of the front. I heard that even makes the stereo sound better!
